Brake Conversions Tech info on converting from drum to disc
Old Aug 10th, 05, 3:26 PM
Limoridr Limoridr is offline
Send a message via AIM to Limoridr
Default 69..What will work
I want disc set up in the front. I got some people telling me, go to the junk yard, blah,blah,blah. Can it really be that easy. If so, what will work? I'm so sure whatever comes from the bone yard will need to be all gone over,turned or replaced. However, it seems like an option I should explore.
Thanks in advance
My hobby's include:
Shopping...
For BowTies
"That what does not kill us, only makes us strange-r"
  #2
Old Aug 10th, 05, 4:11 PM
Cam Sweet Cam Sweet is offline
Gold Member
Default Re: 69..What will work
Absolutely. Rotors may be reusable but most have been turned so many times they are toast. You'll want to put in new remanufactured calipers anyhow and as far as I'm concerned the original dust sheilds for 14" wheels look silly on 15's. Why not modify your existing drum spindles to accept calipers brackets, buy new rotors and rebuit calipers???
Cam
Old Aug 10th, 05, 4:31 PM
Olle Olle is offline
Team Member
If you find a car in a junk yard, keep in mind that there's a reason why it ended up there. If you decide to go the junk yard route, you need to at least get new/rebuilt calipers, master cylinder, brake hoses, rotors, bearings and maybe booster. If you look at it the other way around: the only junk yard parts I would use personally would be spindles, caliper brackets and dust shields, and turn in the rest for cores.
Brake kits are pretty inexpensive now, so that's worth looking at too. It really sucks to do all the work, just to find out that the junk yard master cylinder or booster doesn't work.
1969 Malibu in progress
Old Aug 10th, 05, 8:41 PM
Does anyone out there have a photo of where the existing spindles should be cut?
My hobby's include:
Shopping...
For BowTies
Old Aug 10th, 05, 9:29 PM
Herb Herb is offline
Team Member
Hate to do this to you but there are numerous pics and specs on how to cut the drum spindles to accept disk brakes on this site. (Here it comes) do a search here and in the archives. I know those pics and specs were posted here this year.
BTW - I recently used boneyard spindle assys for my conversion on my 67 (in progress). Saved a bunch of money by buying most of the new assy from e-bay. Got new rotors for about $50, fully loaded calipers for about $35 ea, bearings and seals from NAPA.
This is a note from Pete Lohr's site: http://www.einstyn.com/
’70 (or ’69) Chevelle calipers and spindles fit without any modification. You can use ’69 Camaro front disk brake hoses with the Chevelle drum brake hose frame brackets, they are a few inches longer. Be sure to use the correct “Banjo” bolt. Napa #82701 is 1.1” long. You can also use ’78 Camaro hoses but you will need to use Banjo bolt Auto Zone # 313935 which is .9” long. The ’78 Camaro hoses are cheaper and do not have to be special ordered.
However, if you don't want to go thru all that, Olle knows a source for a reasonable kit. (I don't have the link with me right now) It's also on e-Bay.
Herb Sr
'67 Coupe (frame-off)
489BB/M20/3.73 Eaton posi
http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG
.com
  #6
Old Aug 10th, 05, 11:48 PM
Gold Member
Not ten mintes ago, I was out in the shop measuring a pair. It's just over .500". I take my measurement by attaching the caliper bracket to the lower sterring arm mount and swinging the caliper bracket up until it contacts the boss, and scribe a line. I usually hacksaw off teh majority of the boss and then machine it flat, perpindicular to the line of the spindle. BTW, our sponsor has brackets for like, $85/pr. Iv'e used three pair of tehm so far with great results. A Team Chevelles membership will get you another 10% off.
Cam
You may not post new threads
You may not post replies
Similar Threads
65 body work where to start? jhilb Body Shop 8 Aug 15th, 04 5:36 PM
Need body work in michigan !!!!!!!!!!! stringer69ss Body Shop 1 Jul 25th, 04 12:15 PM
Got a great deal But will it work???????? dizzy66devil Brakes, Suspension & Steering 1 Apr 26th, 04 5:05 PM
32-tooth output spline---will it work? 67Chevelleguy Troubleshooting 1 Oct 29th, 03 3:29 PM
Will this work ??? Nate Brakes, Suspension & Steering 3 May 2nd, 03 8:03 PM
