Brake Conversions Tech info on converting from drum to disc
Old Aug 8th, 05, 10:04 AM
Rich Till Rich Till is offline
Question Altering stainless brake lines, what type of tools?
I have converted my 1970 SS Chevelle over to disc brakes in the rear of the car. I have ordered and received a new power disc brake booster, mastercylinder, and combination valve designed to work with a Disc/disc system.
My problem is that the new combination valve is longer than the original valve and my new stainless lines are going to require shortening and re-flaring.
Can anyone recommend what type of flaring tool will work well for this kind of work on stainless brake tubing? And exactly what type of flare do I need to reinstall on these brake lines for them to seat in the new combination valve?
My stainless lines came from Ground-Up and they look like a standard double flare automotive, but I'm not sure and don't want to screw these lines up without more information. I have a standard flare kit for carbon steel lines, but I dont think that will do the job on stainless. Thanks for any suggestions.
  #2
Old Aug 8th, 05, 11:26 AM
BillsCamino BillsCamino is online now
Gold Founding Member
aka "Wild Bill"
Send a message via AIM to BillsCamino
Default Re: Altering stainless brake lines, what type of tools?
Most aftermarket stainless brake lines are already annealed so re-flaring should not be a problem if you use a quality double flare tool.
'67 Malibu 4dr Sedan, w/ 460 cu,TH400 & 3.73 12 bolt posi
'69 SS 396 w/original L35, TH400, 3.07 12 bolt, factory A/C
Team Chevelle #613
ACES #3920
A.M.C. of Ireland #113
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #102
Old Aug 8th, 05, 1:15 PM
Bill, thanks for the reply back on the flare issue. So, if I understand this correctly, I can cut to length where I need it and use my flare kit that I use on the carbon steel brake lines with a double flare. Does the annealing process allow the brake line enough "elasticity" to flare without splitting? Would you use any lubricant when flaring it because its stainless? Thanks again.
Old Aug 8th, 05, 1:20 PM
aka "Wild Bill"
Originally Posted by Rich Till
1) I can cut to length where I need it and use my flare kit that I use on the carbon steel brake lines with a double flare.
2)Does the annealing process allow the brake line enough "elasticity" to flare without splitting?
1)Yes, I've done it many times.
2)Yes, that is how they're able to be manufactured originally.
And, no lube needed.
You may not post new threads
You may not post replies
Similar Threads
Brake Fluid Type krum1969396 Brakes, Suspension & Steering 2 Aug 10th, 04 8:38 AM
1969 Chevelle, verifying brake and fuel lines needed for restore. Steve Petzer 2004 16 May 5th, 04 12:01 PM
colored clips for brake lines???? Resq302 Brakes, Suspension & Steering 1 Feb 23rd, 04 9:49 PM
Where can I get repro brake lines? 72Elky 2000 14 Oct 11th, 00 9:57 PM
Hard Stainless Lines davewright99 1999 -- 5 Dec 2nd, 99 8:36 PM
