| Chevelle Tech Current Topic: What is used to connect the flex line to calipers? | ||
| Brake Conversions Tech info on converting from drum to disc |
I am nearly finished w/ the drum to disc conversion on the front of my '66. I have new calipers and flex lines, but I seem to be missing a bolt or connector that holds the flex line to the caliper. The flex line has a sort of 90 degree end on it but missing a bolt or whatever is used to connect it. Please help explain what is missing!
66 Chevelle Malibu Convertible 57 Chevy Bel Air 2 dr HT - project car 71 Pontiac Formula 400 - project car http://community.webshots.com/user/bburroughs102 |
#2
Are you referring to the banjo bolt...holds the "block" at the end of the brake hose to the caliper. Uses two copper washers (one each side)to seal.
'67 Malibu 4dr Sedan, w/ 460 cu,TH400 & 3.73 12 bolt posi '69 SS 396 w/original L35, TH400, 3.07 12 bolt, factory A/C Team Chevelle #613 ACES #3920 A.M.C. of Ireland #113 CanAm Chevelles #136 Carolina Chevelles #185 Heart Of Dixie #231 Long Island Chevelles #102 |
Yep, that must be the banjo bolt. The picture below is Year One's part # 9255N, but they should have that and the copper washers at any parts store.
1969 Malibu in progress |
I just bought two banjo bolts today...rebuilding (replacing) the complete factory disc/drum brake system on my '72.
Used Auto Zone part #313935...$3.29 each.
Thanks, yep thats what I'm missing. Suprised one didn't come w/new calipers or the new lines.
Brian
#6
Watch the length on the banjo bolts if you get them from local parts store. Some of these parts are sort of universal fit. When I did the conversion on my 67, one set that I bought only engaged about 2 threads, enough to get tight but not enough to be "right". I got another set from another store that where longer.
Zeke 67 Chevelle 64 Chevelle 69 AMX TC# 3094 ACES# 7297 |
#7
Went to my local Car Quest, they had an assortment of these, but they had no idea which one was correct. I guessed at which one was correct (length was the variable). Got home and checked, there are about 5 or 6 threads engagement and it looks like a good fit.
Thanks for the help!
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Braided fuel line | OUChevelleSS | Performance | 2 | May 5th, 05 2:06 AM |
| How to run fuel line? | jgoggan | Chevelle Tech | 16 | Apr 28th, 05 3:56 PM |
| Fuel pump and line for a 396? | jgoggan | Chevelle Tech | 7 | Apr 8th, 05 11:20 AM |
| Brake line work | dittoz | Brakes, Suspension & Steering | 10 | Mar 20th, 05 12:55 AM |
| routing fuel line | yellow69 | 1999 -- | 2 | Feb 27th, 99 9:22 PM |
