Engine General Engine Discussion
Old Aug 3rd, 05, 5:38 PM
madmax2 madmax2 is online now
Hernan
Send a message via ICQ to madmax2 Send a message via MSN to madmax2 Send a message via Yahoo to madmax2
Exclamation 454 Oil pan & windage tray
Hello I have 454 of two bolts with windage tray and stud.
Now I bought an oilpan that have baffle, but the windage tray and baffle are interfered and I cannot place the oilpan.
they can be together?
The baffle of oilpan and windage tray acts the same as?
Thanks, Hernán
'68 Chevelle Malibu. I have a 454 now!
BB 454 +.040, 049 Heads with 2.19" x 1.88" valves,
Edelbrock Air-Gap RPM, Holley 850 DP,
CompCams XS274S: adv 274º/280º, @050 236º/242º, lift .568"/.578",
Hedman Heeders 1 3/4, 3" pipes.
Muncie M20, DualForce Centrerforce clutch,
12-bolt Eaton posi, 3.73 Richmond gears, Superior axles.
Old Aug 3rd, 05, 10:14 PM
Tom Mobley Tom Mobley is online now
Tom Terrific = Terrible Tom
Tom
Default Re: 454 Oil pan & windage tray
one or the other but not both. if your engine is going into a Chevelle make sure it's a Chevelle pan, most other models hit the crossmember.
Tom
Old Aug 3rd, 05, 10:24 PM
79943 79943 is offline
Bill
i tried to use a windage tray with my 454 chevelle pan and found that the baffle in the pan interfered with the tray. sounds like what you are describing. i just eliminated the tray. i think the baffle serves pretty much the same purpose. apparently the tray can only be used with different pans such as the LS7 type pan which must have more clearance. good luck.
Bill H.
68 Vette/468bbc
ACES Charter Member
‎"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm." - George Orwell –
Old Aug 4th, 05, 3:18 PM
Hernan
Cool Re: 454 Oil pan & windage tray
Thanks.
It was a boat motor and it had a big and heavy oil-pan without baffle for that reason used windage tray .
You may not post new threads
You may not post replies
Similar Threads
Milodon Diamond Stripper and a stock oil pan Rich-L79 Performance 7 Aug 1st, 05 11:07 PM
67 Chevelle Oil Pan & Oil Pump Pickup Rodeo73 Engine 2 May 9th, 05 7:07 PM
Oil pan clearancing against crank? 69boo307 Engine 3 May 2nd, 05 10:00 AM
Oil pan won't go on?? Junkyard Dawg Engine 3 Apr 15th, 05 6:44 PM
SBC 400 with a "MILODON DIAMOND STRIPPER" WINDAGE TRAY DEEBOO Performance 5 Oct 15th, 03 10:15 PM
