Rotella T SAE 30 oil for cam break in? - Chevelle Tech
Auto Insurance
Old Aug 1st, 05, 7:20 AM
cradfordchevy1 cradfordchevy1 is offline
Default Rotella T SAE 30 oil for cam break in?
Would Rotella T SAE 30 weight oil be good for cam break in and provide a good protection for the cam?
Thanks for any help.
Old Aug 1st, 05, 12:50 PM
Schurkey Schurkey is offline
Gold Founding Member
Default Re: Rotella T SAE 30 oil for cam break in?
ANY oil, and a can of GM EOS.
Old Aug 1st, 05, 3:40 PM
ehjorten ehjorten is offline
Erik
I have always stuck with straight 30 weight non-detergent oil for break-in. The non-detergent oil is suppose to help the rings seat faster, but change it after about the first hour of break-in. I have never had a problem with this method. Perhaps it is old-hat, but it seems to work good for me.
Erik
'69 Chevelle Sport Coupe, EFI355, TH350
'68 Chevrolet C10 Stepside Project, 292, t-56, C4 IRS
'77 Chevrolet K20 Silverado LWB, 400CI, TH400
Old Aug 1st, 05, 5:02 PM
Jimmy P Jimmy P is offline
Team Member
Hey!
I ditto the EOS. I would never fire a newly built engine or break in a camshaft without it. Never.
Old Aug 1st, 05, 5:08 PM
BillsCamino BillsCamino is online now
"Wild Bill"
Send a message via AIM to BillsCamino
Isn't that the Shell stuff?
I use Valvoline 30W racing oil AND EOS. The Valvoline has a higher moly content than standard motor oils.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #6
Old Aug 1st, 05, 8:05 PM
northern 396 northern 396 is offline
I recently broke in my 396 with straight 30 weight oil. But, contrary to one post above, the engine builder insisted that I use high detergent oil.
  #7
Old Aug 2nd, 05, 11:50 AM
I think I will use this oil and just put in a can of "EOS" and hope for the best. I am hoping it should be okay.
Thanks for the replys.
  #8
Old Aug 2nd, 05, 2:45 PM
TJ1967SS TJ1967SS is offline
TJ
The story I've been getting about diesel oil (such as Rotella 15-40) is that there is still sulfer in it, which they've eliminated in "gas engine oil" for emissions reasons. But the sulfer content is really supposed to be beneficial to the cam surface. If anyone else has heard this or can give support to the theory, I've been curious myself.
67 Malibu #1: Car Pic
67 Malibu #2: New Project
  #9
Old Aug 3rd, 05, 7:29 AM
JohnC JohnC is offline
John
Where do you get nondetergent oil? I looked when I was getting my cam ready for break in, but reading the bottles at the autoparts store, none of them mentioned detergent free.
  #10
Old Aug 3rd, 05, 12:28 PM
Wooderson Wooderson is offline
The Driver
I've seen the non detergent at Home Depot and at Wal Mart. It will usually be an SA rated oil that may say "suitable for cars produced prior to 1930" or "not for extended oil change intervals." I've seen it around 80 cents or so a quart.
  #11
Old Aug 3rd, 05, 9:41 PM
You might want to ask for more information on this high-detergent vs non-detergent thing during breakin. Some shops will void your warranty if they know that you break it in with non-detergent oil. Rotella T probably is a high detergent oil - many or most diesel oils are.
I don't know much about the theory behind this and wonder what those who design oils would say about it.
  #12
Old Aug 4th, 05, 7:30 AM
427L88 427L88 is offline
Gold Member
Gene
Zinc, sulpher and some other "nasty" things still appear in diesel "fleet" oil.I run a solid flat tappet cam, so I've run the motor on Pennzoil 15-40 fleet. Used to be ableto buy at WalMart in 5qt bottles,but no more. Rotella and Delo are two other brands of the same good stuff.)
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
  #13
Old Aug 4th, 05, 11:29 AM
engineguy engineguy is offline
Bill R
If you have a Tractor Supply store near you, they have their own brand of diesel oil in larger containers (5 or 6 quart jugs, I think).
I don't know much about oil, but usually the cam manufacturer will recommend that oil with certain SAE designations eb used with their cams. The SAE designations are listed on the oil containers and the cam manufacturer's recommendation should always be followed to the letter.
Bill
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (20+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
  #14
Old Aug 4th, 05, 12:21 PM
OUChevelleSS OUChevelleSS is offline
Send a message via AIM to OUChevelleSS
I used the Rotella oil in that weight when I broke in my 454. No problems, BUT I still used a liberal amount of EOS in the crankcase and during assembly.
Taylor
'71 SS 350, Black w/ white stripes, now a '71 SS 454! Brodix Race Rite heads w/CNC, SRP pistons, ~10.2:1CR, 402A3LUN Solid cam, Edelbrock Performer RPM intake, Holley 850cfm double pumper, Tremec TKO-600 and a 4.11 posi 12-bolt rear.
  #15
Old Aug 4th, 05, 2:35 PM
I am for sure going to use it with EOS and a moly lube.
I think it should be okay.
Thanks for all the replys.
Chevelle Tech > Mechanical > Engine      Current Topic: Rotella T SAE 30 oil for cam break in?
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Stock volume oil pump with direct lube solid lifters ?? HPseeker Performance 22 Jul 21st, 06 9:25 PM
Best oil to use for break in st70chevelle Engine 14 Jun 8th, 05 12:23 AM
oil cooler recommendations turbodave Performance 2 Jun 4th, 05 4:45 PM
Milky oil.....help! (long) IROCJOE Engine 10 Apr 11th, 05 11:04 PM
break in oil? bentjenson Engine 2 Apr 11th, 05 1:24 PM
