cam specs 375 HP 396 - Chevelle Tech
Auto Insurance
Old Jul 31st, 05, 3:54 PM
robbieg454 robbieg454 is offline
Default cam specs 375 HP 396
where can I find the cam specs for the 375 HP 396 I want to use a auto with a hyd cam. thanks in advance..
rob
IF YOUR GOING TO BE DUMB YOU HAVE TO BE TOUGH
Old Jul 31st, 05, 6:14 PM
pdq67 pdq67 is offline
Guest
Paul
Smile Re: cam specs 375 HP 396
Here it is.
242/242, 114/108, .520"/.520" gross lift and lash at .024"In/.026"Ex.
GM called it a 307/298 and a 316/302 cam, (Chevy Power books 6th and 5th editions). Crane doesn't list advertised duration even though they are licensed to re-pop it and WBR call's it a 336/316.
Also HPBooks call's it a 306/306, so go figure.
Imho, I figure a good old CC 280 Magnum should be a good hy-cam match for it
pdq67
Old Aug 1st, 05, 10:40 AM
427L88 427L88 is offline
Gold Member
Gene
Default Re: cam specs 375 HP 396
FOr a hyd equivalent look for something like 227/232@.050 and shorter
seat figures, like 268-280.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
Old Aug 1st, 05, 11:34 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
Comp makes a 279 Nostalgia flat tappet hyd that is supposed to have the idle and sound of the 396/375 in a hyd cam.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old Dec 6th, 05, 9:49 AM
pbhammes pbhammes is offline
How would I find out more info on the comp cam for a 66 396/375hp?
  #6
Old Dec 6th, 05, 10:19 AM
Mike Feudo Mike Feudo is offline
Is there a reason you want the same cam? It's a very old design and the newer stuff is far superior. The idle really isn't that nasty and the cam not that big for the duration numbers at .050.
  #7
Old Dec 6th, 05, 11:27 AM
von von is online now
Lifetime Founding Member
Von
Get a UD/Lunati 272/272 solid cam. It's advertised as a LS-6/L-78 replacement cam. 238/238 dur @ .050. .550/.550 gross lift, 112 LSA .022/.022 lash. It idles just like the factory cam but has much more low end and mid range. BTDT.
von '69 300 Dlx SS '69 Malibu TC #15 ACES #1575 HSCA #5
http://www.chevelles.com/showroom/da...m/DSCN1135.JPG
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
  #8
Old Dec 6th, 05, 4:57 PM
I do not know that much about cams, but what I am looking for is a stock sounding375hp cam that performs better without all the constant adjustments of a solid lift cam. I have power drum brakes. I have the 858 sq.port heads and a 962 block punched to about a 427.
  #9
Old Dec 6th, 05, 6:15 PM
Keith Tedford Keith Tedford is offline
Keith
From my personal experience, setting the solid lifters all the time is a myth. I probably put close to 200K miles on our COPO Chevelle without constant adjustment. In 28K miles on our L78 Chevelle, I checked the lifter clearances once and they were fine. If you have to set your lifters all the time, you have problems elsewhere. Rocker nuts backing off, keepers pulling, rocker studs pulling or backing out, or other problems may be present. Over the years there will always be a minor amount of valve train wear that will have to be adjusted for. If you start running big valve spring pressures, these problems will be magnified. With stock type valve springs and the amount of driving that most people do, adjustments will be few and far between. Besides, do you really want to lose the solid lifter sound?
  #10
Old Dec 6th, 05, 6:47 PM
79943 79943 is offline
Bill
i agree with this. i had an ls6 for around 5 years and probably only adjusted the lifters 3 or 4 times and then they barely needed a tweak. i was told once (by an engine builder) that an engine that came from the factory with solids such as the ls6 or l78 were different than when you installed a non oem unit in that the factory deals did not require nearly as much adjustment. that really didnt make sense to me. has anyone else ever heard that? BTW around 1982 i was scrounging a parts shop for some BB components and ran into a NOS l78 cam still in the tube. i picked it up for $25 didnt end up using it and either tossed it or gave it away. sure would like to lay that on ebay for a few days.
Bill H.
68 Vette/468bbc
ACES Charter Member
‎"When the drums stop...it's time to worry"
  #11
Old Dec 6th, 05, 8:52 PM
Guest
Paul
I think Gene, (427L88) and Von hit the nail on the head, BUT...
Here is CC's Nostalga + LS-6 hy-cam you asked about.
PN 11-670-4, 276/229/283/236, 112/?, .530"/.524".
Vs GM's LS-6 at;
316/242/302/242, 114/108, .520"/.520" gross lift and lash at .024"In/.026"Ex.
Notice that you can't compare them b/c one is a hy- and the other a solid!!
The deal with the factory solid cams vs the more aggressive aftermarket solid cams is just that!! A factory warranteed cam vs an aggressive aftermarket solid cam!!
pdq67
PS., and I am a solid cam guy and have daily driven a factory solid cam a long time way back when with no issues with tappet noises! I just checked it say, every third or forth oil change or when it started to "sewing machine" a bit is all..
AND I like the about 4 percent more power everywhere a solid cam will generally produce over and above an identical acting cam spec'ed as a hy-cam!!
Chevelle Tech > General Tech Area > Performance      Current Topic: cam specs 375 HP 396
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Need stock cam specs from late 350 roller BlackNBlue65 Engine 3 Jul 21st, 05 11:14 AM
cam specs help big bird Engine 1 May 18th, 05 1:18 PM
Sorry but...what do my cam specs mean. Grape Ape Performance 7 May 1st, 05 11:27 AM
396 cam Q? Bernie396 Performance 3 Apr 17th, 05 11:28 PM
Stock 325 horse 396 cam specs? fast67vellen2o Chevelle Tech 5 Mar 30th, 05 8:06 PM
