Brake Conversions Tech info on converting from drum to disc
Old Jul 30th, 05, 2:37 PM
johncolvin johncolvin is offline
John
Default Correct brake lines
I have a 66 Chevelle with 72 Chevelle spindle setup. I ordered the brake lines with this information and the guy said I would need brake lines for a 72 chevelle. Is this correct? I just want to make sure before I get knee deep.
LS1 1966 Chevelle Malibu
  #2
Old Aug 1st, 05, 12:13 AM
red68chevL red68chevL is offline
Scott
Default Re: Correct brake lines
do you mean 72 disc brakes? or just 72 spindles? if its discs, get 72 lines. you may come into some problems with the bracket on the frame where the hoses meet the hard lines....
Scott W. ACES#6211
Electrical Engineer (In Training)
'68 Malibu 327SJ TH350, VooDoo 268, New: Hydroboost!
I miss the good ole days, just wish I was around for them the first time!
It's a Family Affair! (CB 2006) CB'08
Old Aug 1st, 05, 11:22 AM
MedicTed MedicTed is offline
Try these places. I am sure that you can tell that exactly what you have and they will make the correct lines for you.
http://www.rightstuffdetailing.com/
http://www.classictube.com/
Ted
King of Prussia, Pa
64 Chevelle Malibu convertible
74 VW Thing
03 GMC Sierra
Old Aug 2nd, 05, 12:36 PM
John
It is the '72 disk brake setup (spindles, calipers and rotors).
Old Aug 2nd, 05, 1:25 PM
540cutlaSS 540cutlaSS is offline
Off hand I would think you would want the 66 hard lines and 72 flex lines to the calipers?? If everything else is in its stock location, MC, prop valve.....
NCOA Member # 14002
Life is hard, it's harder if you are stupid. (John Wayne)
OO SS OO
  #6
Old Aug 2nd, 05, 6:04 PM
John
That's the thing, there is not a stock location for the MC, booster, prop valve since this is a disc conversion. There was not a stock location for 66 disc brakes - was not an option (I don't think). The MC and booster is off a '68 chevelle and the spindles, rotors, etc. are off a '72 and I'm using the '66 control arms. Thanks so far for everyone's help. More suggestions would be appreciated.
  #7
Old Aug 4th, 05, 10:59 PM
Herb Herb is offline
Team Member
I just ordered lines for my 67 with 69 front disc conversion. The folks at "The Right Stuff" said I needed 69 front and intermediate lines, and 67 rear lines. I questioned the '69 intermediate lines and he said you always use those lines to match the conversion. If it's not right, they will make it right.
We'll see, when I put them on.
Herb Sr
'67 Coupe (frame-off)
489BB/M20/3.73 Eaton posi
http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG
.com
  #8
Old Aug 16th, 05, 4:08 AM
Chris R Chris R is offline
Team Member
Thats the same problem I had with my 66 too. Since there was only a single reservior in 66. You run into problems ordering a kit for disc brakes on a 66. I had to wing it and get classic tubes kit for a 66 and use some extra stainless lines they sent to run the extra lines. I couldnt even use the stock brake line that runs to the right front wheel at all. I had to get a regular steel line from a parts store and bend and flare that side. Dont be supprised you need to do some of your own fitting to make this all work. Thats what I had to do.
Chris.
If it aint broke, just give me a minute.
You may not post new threads
You may not post replies
Similar Threads
1967 drum to power brake lines dkemerley Brake Conversions 0 Apr 21st, 05 3:54 PM
new brake lines, how to bleed? lincoln31 Brakes, Suspension & Steering 13 Apr 13th, 05 1:18 PM
brake and vent lines bills71 Brakes, Suspension & Steering 0 Jul 26th, 04 9:41 PM
Brake lines zefhix Brakes, Suspension & Steering 4 Jun 3rd, 04 6:44 PM
Brake Lines Digital Biterate 2001 1 Aug 9th, 01 11:24 PM
