Wagner Power Painter to Paint a Car? - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Jun 7th, 03, 1:48 PM
Moloko Moloko is offline
Send a message via AIM to Moloko
Post
Ok, this may seem crazy but is there a good reason why I shouldnt use a Wagner Power Sprayer to paint a car? Hey now, dont laugh right away. They make some pretty nice ones. We sell a middle of the road one where I work that puts out 1300psi and has multiple speeds and spraying paterns. I know it wont do the best job, but would it probably turn out better than Macco? I am trained in paint and body, but I have no access to an air compressor nor do I have power in my garage to use one with.
Old Jun 7th, 03, 1:55 PM
drptop70ss drptop70ss is offline
Hoarder Deluxe
Post
I know someone who did it, but of course he shot house paint through it..spray cans would of came out better.
Dave
66/68/70 chevelles
55/57/61 belairs
69 70 71 72 novas
37 Buick 47 Cadillac 51 Ford F1s
other money pits and projects
Old Jun 7th, 03, 1:59 PM
Post
Well keeping in mind that I would sand it properly and not use a crappy version of it, would it at least turn out somewhat good with white paint? Either that, or do places rent sprayguns?
Old Jun 7th, 03, 2:04 PM
daveseitz daveseitz is offline
Post
I used to work for Wagner, so I know what you want and need. The lower end cup guns will do the job if set up properly.
1.Find a Fan pattern or V pattern nozzle if you cannot a small diameter nozzle.
2.They make a Swirl valve for petroleum based products, you MUST use one of these.
3.Solid colors are the easiest to spray and less likely to blush,zebra stripe or mottle.
4.All components need to be cleaned before you start mixing paint.
5.PRACTICE PRACTICE PRACTICE
When I worked there I used to paint cartoons on the side of a building they owned. I also worked in R&D testing all types of materials to spray.
Mess with me, and you mess with the whole trailer park!
Old Jun 7th, 03, 2:11 PM
Post
Do you recommend any certain gun? I can probably get about anything since I work for Ace Hardware.
  #6
Old Jun 7th, 03, 2:22 PM
Post
Skip any of the guns with electronics, you don't need it. The low end guns will work the best as they have a smaller motor. The smaller motor and tip will help you keep from running paint. Solid colors will work best and plan on wet sanding. You will need masks and ect, they will create overspray. Biggest thing is practice!
  #7
Old Jun 8th, 03, 1:29 AM
Corey872 Corey872 is offline
Post
If you don't have power for an air compressor, how do you have power for a paint sprayer?
I would think that by the time you buy a power painter and the tips to go with it, you could rent a 3-5 HP compressor and a gun for the weekend and do the job (semi) correctly.
Several years ago, a friend of mine thought he would paint his old 4x4 with a Wagner...he mixed up his whole gallon of paint with hardner and accelerator, clipped on the "suck from the gallon can" attachment and painted for about 3 minutes before the gun seized up...spent about 15 minutes cleaning and another 2 painting before it seized again. About that time, the whole gallon of paint went ballistic because of the heat generated by the hardner/accelerator. Not a pretty sight!
I know he probably didn't have the proper parts in the gun. I also know they make parts for latex and parts for oil based paints but (maybe daveseitz knows) do the parts for oil based paints stand up to the hotter solvents like xylene and toluene found in automotive paints?
If it were me, I would say why not do a decent job to start with and spend the time with the details instead of on getting the paint to look "OK".
Corey<br /><a href="http://www.sunflower.com/~corey872" target="_blank">Corey's 67 Chevelle Page</a>
  #8
Old Jun 8th, 03, 8:37 AM
Post
I'd have to run any power off an extention cord. Before we moved into this house the power to the garage was cut by a lawnmower and the land lord refuses to fix it and says that we are not allowed to fix it. I would'nt feel safe running an air compressor off a 100ft extention cord.
  #9
Old Jun 8th, 03, 9:05 AM
cjlandry cjlandry is offline
Post
You could rent a gasoline powered air compressor.
I use a Wagner around the house, and that thing makes more overspray than anything I've ever seen.
Chad Landry
Real treasures give you hugs.
The rest is just stuff.
  #10
Old Jun 8th, 03, 7:17 PM
Hoarder Deluxe
Post
I agree on using the gas powered compressor, that is what I used for years when painting cars. The gas powered ones recover faster and can keep up better than similarly sized electrics. I have an emglo 5hp and it worked great for painting.
Dave
66/68/70 chevelles
55/57/61 belairs
69 70 71 72 novas
  #11
Old Jun 8th, 03, 9:57 PM
boomhauer boomhauer is offline
Post
For what the average Joe will pay for a one timer on paint/materials/spray gun, compressor ect. you would be better off getting the $299 special at Macco. Macco sucks but it will be better than with a wagner or a rattle can.What kind of car are you painting?
  #12
Old Jun 8th, 03, 11:16 PM
Post
Im painting my Daytona. My friend can get me free PPG paints, so I figured it might be worth trying myself, if I screw up I'll strip it down again and take it to Macco and use the powerpainter to paint my garage.
  #13
Old Jun 10th, 03, 11:24 AM
Buzzbomb Buzzbomb is offline
Roland
Post
If you get free PPG paint, why not do as others suggest and rent a gas compressor and do it right? Its not like you are having any cash outlay on materials, right? I've seen a Wagner painted vehicle and it SUCKED. IMHO, even with the "proper" setup with a Power painter, it still wouldnt be as good as a half assed REAL spray gun job.
"The man who lets a leader prescribe his course is a wreck being towed to the scrap heap."
-Ayn Rand
  #14
Old Jun 10th, 03, 11:28 AM
Post
I didnt even know they mad gas compressors until you guys mentioned them. Im actually prepared to buy one. Any sites you know of that sell them?
  #15
Old Jun 10th, 03, 12:01 PM
1966_L78 1966_L78 is offline
Tony
Post
I have seen a few cars up close that were painted at Maaco-type shops (competitors)... There were not that bad...
In fact, I had a 66 El Camino, that place 2nd in its class (out of about 15-20 cars) with a $350 paint job, and that cost included painting the stock wheels, bed and door jambs (okay, it was 10 years ago)...
But with proper prep on your part, I think you can get a decent job from these places...
As for the compressor, gas is a good choice, but why the worry about the extention cord? Buy some HD Romex, etc and some ends and make your own Heavy Duty cord... I'd figure which compressor you'd rather have in the future (when you do have the proper electrical), and think about that one...
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Wagner Power Painter to Paint a Car?
Human Verification
