| Chevelle Tech Current Topic: 64 drum/disc swap from a 70's a body | ||
| Brake Conversions Tech info on converting from drum to disc |
Tried doing a search and coudn't find any info. Maybe I'm just tired.
My situation 64 elky 4 wheel drum. Want to convert to front disc. have all components from a 70's A body to donate. Will the spindles swap over? will probably use a s10 master and booster(smaller) Plumbing and proportioning is no problem I just need to know if the factory hardware will interchange. This way i can put a Baer setup on the A body donor
Philip Mullaly Machines don't matter.... People matter |
#2
Yes, they will work. The spindles are a direct swap from any A-body 64-72.
Derek Kiefer, member of Minnesota's Northstar Chevelle Club 69 Malibu Pro-Touring - 69 Chevelle SS396 - 66 Chevelle Wagon - 95 Caprice Wagon -23 Model T Ford |
Thank you
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 65 body work where to start? | jhilb | Body Shop | 8 | Aug 15th, 04 5:36 PM |
| 65 body swap Is it possible? | jeffkaiser | Restoration Corner | 9 | May 5th, 04 1:14 PM |
| Frame off support | Clays72ss | Restoration Corner | 3 | Jan 29th, 04 9:41 AM |
| Question about body to frame mounts on 65 chevelle | bhawk | 2002 | 4 | Aug 27th, 02 9:18 AM |
| Ideas | Lou Merrell | Top Tech | 3 | Feb 2nd, 01 6:41 PM |
