Vacuum Diagram 72 Chevelle w/ AC - Chevelle Tech
Auto Insurance
Heating & Cooling Heating, cooling and air conditioning
Old Jul 17th, 05, 9:03 PM
Restoring70Malibu Restoring70Malibu is offline
Default Vacuum Diagram 72 Chevelle w/ AC
Can someone e-mail me or post a copy of the vacuum and wiring diagram from the assembly manual for a 72 Chevelle with AC? I have the assembly manual for a 70, specifically sheet E3, but the donor was from a 72 Chevelle and there are subtle differences. We have a vacuum tubing and grommet for a 70 that goes through the firewall to the vacuum operated heater water coolant valve, but it is missing the plug that connects to the three ports on the bottom of the control assembly. Since 72's did not have the heater water control valve, I think that the vacuum line was deleted from the 72 plug for port #2 and so I will have to modify the existing plug for the 70 tubing. This is much harder to explain than it realy is, so can someone please send a copy of the diagram? Thanks ahead of time.
Jeffrey Hicks
70 Chevelle 402 30 Over, Stock Crank/Rods, 190 Dome Forged Pistons, Ext Energy Comp Cam, 215 Heads/Std Valves, 10:1, Edelbrock Perf 2.O Al Intake, Holley DP, Dyno @375Hp&425ftlbs, >400@2900-4600, TH400, Eaton Posi/4.10 Richmond Gears
Old Jul 22nd, 05, 11:24 AM
68Malibu 68Malibu is offline
Default Re: Vacuum Diagram 72 Chevelle w/ AC
Call Year One. They faxed a wiring diagram to me last week. 800 year one.
Chevelle Tech > Mechanical > Heating & Cooling      Current Topic: Vacuum Diagram 72 Chevelle w/ AC
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Belt diagram & vacuum question 72Stroker 2004 6 Dec 7th, 04 12:51 AM
TOTAL Distributor advance----with or without vacuum DZAUTO 2004 14 Aug 27th, 04 5:28 PM
Vacuum line diagram for Heater & A/C system Big E Heating & Cooling 0 May 18th, 04 9:45 AM
which vacuum canister? BIGMOE65 Performance 2 Nov 10th, 03 8:12 PM
Complete Detailed wiring diagram of 66 Chevelle Stroked66 Electrical & Wiring 5 Jan 8th, 03 9:43 PM
