Brake Conversions Tech info on converting from drum to disc
Old Jul 10th, 05, 12:08 AM
Pro68Camaro Pro68Camaro is offline
Default Is there more than one booster choice??
Is the booster for power drum different than for power disc? The reason I ask is the push rod (to pedal) on the booster I got from the auto supply is too short to reach my brake pedal when it is at rest on the rubber stop. It had manual drum before. In order to thread into the rod, the pedal is a good 1" off the rubber. Do I need use a disc brake car's pedal assy - is it somehow shaped different? The pedal arms don't interchange they're bent different- I'd have to get the whole under-column assy. I'm about to fabricate a new, longer swivel piece to thread the push rod into. There goes those show points again!
  #2
Old Aug 2nd, 05, 2:13 PM
T-Man T-Man is offline
Gold Founding Member
Tom
Default Re: Is there more than one booster choice??
Just went through this earlier this spring. The brake pedal won't come close to the rubber stop like the manual brakes did, GM put a small metal "extension" in the top hole of the brake pedal to extend out to hit the stop light switch. I have no idea where to find one other than a junk yard.
Never be afraid to try something new, an amateur built the Ark, professionals built the Titanic.
Team Chevelle Gold #33
ACES Member #2913
The Chevelle Club of Michigan, serving the Chevelle community since 1976
http://www.chevelleclubofmichigan.com/
Old Aug 5th, 05, 12:35 AM
Don't you want the brake pedal to rest on the rubber stop?? I can adjust the switch, it's the arm suspended (all likely pulling on the rod) that I'm concerned about. I'm about to fabricate a longer pedal to pushrod connector to allow it to rest on the stop.
You may not post new threads
You may not post replies
Similar Threads
67 Malibu power booster renegade Brakes, Suspension & Steering 0 Jul 31st, 04 6:54 PM
Brake fluid in the booster MikeD70Malibu Brakes, Suspension & Steering 2 Jul 29th, 04 12:09 PM
Power booster ? Don Boc 2001 1 Aug 25th, 01 8:44 PM
70 brake booster install from manual brakes. red2rider 2000 1 Jan 5th, 01 3:41 AM
71 All Drum-Power Booster kcooper225 2000 2 Oct 15th, 00 10:25 AM
