Brake Conversions Tech info on converting from drum to disc
Old Jul 6th, 05, 2:43 AM
JayJ JayJ is offline
Send a message via AIM to JayJ
Default Help with rotor fit problem
The rotors I am using for my disc conversion wont fit all the way onto the hub. Correct bolt pattern but get hung up. See picture. Can I just take enough material off the inside so they fit? What problem might this cause?
The caddy rotors fit over the hub, but are not "hub centric" (one word?). They would need to be redrilled for the correct bolt pattern but are larger than the hub so they arent hub centric either.
  #2
Old Dec 14th, 06, 11:14 PM
lnbmike lnbmike is offline
Default Re: Help with rotor fit problem
can you send me the pics? I'm having trouble opening them up on this site.
lnbmike@yahoo.com
Old Dec 14th, 06, 11:29 PM
Derek69SS Derek69SS is offline
Team Member
McLovin
Have the hubs turned down to fit inside the rotors.
Pic doesn't work BTW
You may not post new threads
You may not post replies
Similar Threads
Help! Ground problem? Neutral switch problem? New engine won't fire! OUChevelleSS Electrical & Wiring 2 Mar 21st, 05 1:05 AM
99 Grand Prix, Starting problem on hot days Bill T SS70 2003 5 Jul 23rd, 03 1:59 PM
DNS problem with TC? Chevello Bug Hunt 6 May 8th, 03 3:25 PM
Update on pass side oiling problem...You WONT believe this! MY70Chevelle 2002 13 Nov 11th, 02 1:36 PM
ATTN: SS_Dave, d1_bradley, and others-Update on 68 cowl to hood seal problem. Paul Lower SoCal Body Shop 17 Sep 3rd, 02 11:34 PM
