Tranny codes...what kind is it? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Jul 2nd, 05, 10:17 PM
Paul's '66 in PA Paul's '66 in PA is offline
Question Tranny codes...what kind is it?
Can someone help me with decoding the type of transmission I have?
4 speed.
Here are the numbers and location:
code location
3952659WB drivers side by clutch linkage
38575846M passenger side drive shaft enters
392566 US Patent 3088336 General Motors Corp P0524A..on passenger side midway on tranny
I was told it is a Muncie.
Thanks for your help
Old Jul 2nd, 05, 10:32 PM
David Bates David Bates is offline
Dave
Default Re: Tranny codes...what kind is it?
1970 wide ratio (2.52 1st gear) assembled May 24th.
Dave
USAF Retired (1968-1988)
UTC Aerospace Systems, Space Systems International - Retired (1989-2014)
Old Jul 2nd, 05, 10:38 PM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
392566 -
i think thats the number you need. the big print one. there should be a zero at the end (after the 2nd 6). it is the same as mine...
which would be a 68-70 m20,m21,m22 case
P0524A
P-Muncie 4spd
0-is the year 1970
5-im guessing its the month, which is May. (most of them should have a letter for the 3rd digit, which would represent the month, like A for Jan. B for Feb, and so on).
24- 24th day of the month
A-m20 2.52:1 first gear, wide ratio
so all in all, its an M20 wide ration tranny, built on May 24th, 1970
aaron
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
Old Jul 2nd, 05, 10:39 PM
Aaron
ah u got to it before i did dave. you must of posted while i was still trying to right it up.
aaron
71 chevelle
Dyno video NA
Old Jul 3rd, 05, 9:00 AM
Thanks for the info. Can you explain the term "wide ratio"?
  #6
Old Jul 3rd, 05, 9:48 AM
JodysTransmissions JodysTransmissions is offline
Jody
In your case, wide ratio refers to a 2.52:1 first gear verses the close ratio transmission with a 2.20:1 first gear.
Regards, Jody
  #7
Old Jul 4th, 05, 2:22 AM
DZAUTO DZAUTO is offline
Team Member
Tom
Wide ratio vs close ratio relates to the spacing of the gears.
What that actually means in regards to driving is that there is not as much change in engine rpm between gears with a close ratio as there is with a wide ratio.
Generally speaking, the wide ratio is the more compatable tranny for a street dirven car that has a fairly high geared rearend, such as a 3.08, 3.31, 3.55. The close ratio is more compatable with a performance geared rearend such as a 3.70, 4.10, 4.56.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
Light travels faster than sound. That is why some people appear to be bright until you hear them speak. (unknown)
  #8
Old Jul 25th, 07, 11:30 PM
1974grad 1974grad is offline
Greg
Tom,
Great reading you input, what make it compatible? Gas mileage or quick off the line starts or just cruising down the highway.
Thanks, Greg
1970 and 65 Chevelle "newbie"
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Tranny codes...what kind is it?
Human Verification
Similar Threads
motor and tranny in at same time?? THE DUDE Performance 9 Mar 23rd, 05 10:28 AM
Tranny isn't working at all after shift kit installation... fat jonny Transmission & Driveline 4 Jul 30th, 04 8:50 AM
new dealer tranny in 94 Chrysler Town and country down shifting all the time? hilljack Transmission & Driveline 8 Feb 27th, 04 1:42 AM
Water in my TRANNY jcchevelle Transmission & Driveline 8 Oct 27th, 03 7:47 AM
Replacing Clutch - which Kind?? MoparMan 2000 13 Jan 8th, 01 10:42 AM
