Brake Conversions Tech info on converting from drum to disc
Old Jun 27th, 05, 5:40 PM
Pro68Camaro Pro68Camaro is offline
Default Power Booster Push Rod Length
My '72 is auto trans and manual drum (it has the wide brake pedal). I bought a rebuilt booster to use in my disc conversion and found the pushrod would barely thread into the bracket on the brake pedal (which I moved to the bottom hole). My total pedal travel is much reduced. It is such that I had to screw the brake light switch all the way in to cause it to actuate when the brake pedal is at rest (which is now a good ways off the rubber bumper). Is this normal or does something else need to be changed also? Is the pedal travel sufficient?
Man, I thought this was going to be a simple conversion!
  #2
Old Jun 27th, 05, 6:55 PM
thunderstruck507 thunderstruck507 is offline
Default Re: Power Booster Push Rod Length
there should be a bump tab that bolts on in front of the pedal so that it doesnt come back as far from the floor for disc applications
1971 Chevelle SS clone
cammed ls1, 4l60e, 3.42 12 bolt
http://members.cardomain.com/thunderstruck507
You may not post new threads
You may not post replies
Similar Threads
383 stroker. 70chevelle_Z06 Performance 15 Jan 29th, 07 1:22 PM
Brake power booster air noise c.c.c Brakes, Suspension & Steering 0 May 24th, 05 10:30 PM
Power loss with mid length headers? caru68 Performance 5 May 17th, 05 4:17 PM
Power brake booster questions Chevy 70 SS vert Brakes, Suspension & Steering 2 Mar 10th, 05 12:49 PM
Booster push rod length help blumont Brakes, Suspension & Steering 1 May 17th, 04 8:59 PM
