Best way to convert or neutralize rust - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Feb 16th, 03, 8:22 PM
bsmith411 bsmith411 is offline
Default
What is the best way to convert or neutralize rust that has slighty pitted the metal but cleaned up good when blasted? Do I just need to etch prime or use something like one-step rust converter in a can? THANKS
Old Feb 16th, 03, 8:43 PM
Randy Mosier Randy Mosier is offline
Default
What area of the vehicle are we talking about? Blasting is the best way to get rid of most rust, and you've already taken care. Avoid the rust converters like Metal Doctor. Depending on where you're doing this repair, you can either use a rust preventative coating like Por 15 or Eastwood's Corroless. If this is exterior sheetmetal, you can simply use a glazing compound like Evercoat's Metal Glaze. Afterward, use an etching primer, filler primer, and paint.
Old Feb 16th, 03, 9:23 PM
jtjohnston jtjohnston is offline
Default
Everyone talks about POR. I've had success with Phosphoric acid, in dilutions. It eats the rust & leaves a coating. Expensive but chemically correct.
Old Feb 16th, 03, 10:23 PM
Default
The places I'm talking about is a place or two on the radiator support and a couple on the front floor pans.On one reply is the phosphoric acid your talking about like the rust neutralizer ospho which is a green looking liquid? Thanks for everyone's reply!
Old Feb 17th, 03, 12:48 AM
Default
Ospho might be the stuff. I googled it to be sure. Get the gel, not the liquid. Let is dry, brush it off with a wire wheel and do it again, and again. I've used that stuff before but dip it and leave it.
Remove the part buy the gallon and dip it: http://www.jamestowndistributors.com...html?E+scstore http://www.hillmanmarine.com/hullmaint/rust.html
Paiont immediately. Then use POR.
I've also seen an article using an anode a battery and some form of arm & hammer powder.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Best way to convert or neutralize rust
Human Verification
