| Chevelle Tech Current Topic: Rear brake lock-up | ||
| Brake Conversions Tech info on converting from drum to disc |
I did a search and found some info, but nothing that seemed to fit. Converted a 1969 drum brake car to ZO6 front calipers/rear drums. Somebody recommended that we install a prop valve. Had one installed, along with pre-bent lines to fit, and a master cyl for a front disc brake Chevelle. Within a week the back brakes locked up. The left rear brake released, then the right rear, throwing the car into a skid.
Had brakes inspected and inspector said rear brakes showed excessive heat and discoloration, possibly due to incorrect brake line pressure to rear brakes. I found a post that said the 1969 Chevelles don't use a prop valve, but rather a metering or check valve (can't remember which now). Is that the problem? The prop valve is less than an inch from the exhaust header. Is that a problem? Thanks.
Hot Rodding: Turning Money into Noise When you don't know where you are going, any road will get you there - Will Rogers |
#2
I'm sure others can pin point your issue but I do know there is a ton of info on this already published in this group. Did you do a search. The 69 is one of the most commonly used conversion set up so I'll bet you can easily find all your answers.
Herb Sr '67 Coupe (frame-off) 489BB/M20/3.73 Eaton posi http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG .com |
Yes.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Disc Brake Upgrades--Jury Pool Statements 2 | Ike | Brakes, Suspension & Steering | 3 | Dec 26th, 07 1:15 PM |
| rear parking brake cable install | Denny Huron | Brakes, Suspension & Steering | 1 | Jan 5th, 05 10:32 AM |
| Suburban Caliper vs Chevelle Caliper B-Body Spindle | the walrus | Brakes, Suspension & Steering | 10 | Mar 11th, 04 1:20 PM |
| Rear Disc Brake QUestion | jerry396ss | Brakes, Suspension & Steering | 2 | Dec 1st, 03 1:06 PM |
| Front to Rear brake line, Please Help! | Rreemo | Brakes, Suspension & Steering | 4 | Jun 24th, 03 1:50 AM |
