| Chevelle Tech Current Topic: Brake line swap for drum to disc swap? | ||
| Brake Conversions Tech info on converting from drum to disc |
I'm in the process of swapping the manual drum on my '72 to power disc. I got the donor stuff from a '71 Elky. I got the Master-to-combo valve lines and combo valve off the Elky also. Shouldn't the line from passenger to driver side for the front brakes off the manual setup fit the new combo valve or do I have to bend it some? Also, do I need one of those brackets to mount the combo valve or can I just bolt it to the frame with a spacer? Thanks.
#2
Typically the hose mounting tab is in a different location on a drum car than a disc, so no they should not be interchangable.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brake Line Sizes??? | Rick Bandy | Brakes, Suspension & Steering | 2 | May 20th, 05 4:26 AM |
| Disc Brake Conversion,Brake Line Sizes? | Rick Bandy | Brake Conversions | 0 | May 18th, 05 9:31 PM |
| 1967 brake and fuel line routing questions | Frankyboy455 | Brakes, Suspension & Steering | 1 | Jan 26th, 05 9:14 PM |
| 1966 disc brake line question | MARINA66SS | Brakes, Suspension & Steering | 1 | Feb 12th, 04 6:11 PM |
| Brake Line Routing | Johnny_pugh | Restoration Corner | 3 | Jan 19th, 03 8:27 AM |
