Brake Conversions Tech info on converting from drum to disc
Old Jun 8th, 05, 9:54 PM
surfingreg surfingreg is offline
Unhappy Rear Disc Brakes & Wheel Wobble
I have a 68 SS which I converted to rear wheel discs... The process was easy enough and things seemed to go well....I then put TTII's on it and drove away.....A friend was behind me the other day and then told me my left rear wheel seems to have a wobble. I don't feel it in the car, but I put the rear on jacks, put it in gear and low and behold left and right wobble slightly....Left seems worse than right....Balance? Conversion? Any ideas? I'm inclined to pull the calipers and rotors, remount the rims right on the axle to see if its the rotor seating or not....The whole car is basically new, so troubleshooting is an ongoing process....Thanks...
Greg
68 SS396 frame off - Done at last!
65 Malibu 4 door - Calif.black plate car
2008 EC 135 Helicopter (not as powerful as the 68, but still fun!
http://www.chevelles.com/showroom/da.../68SSFront.JPG
http://www.chevelles.com/showroom/da...m/68SSRear.JPG
http://www.chevelles.com/showroom/sh...hp/photo/18042
  #2
Old Jul 7th, 05, 6:36 PM
projekt70chevelle projekt70chevelle is offline
Send a message via AIM to projekt70chevelle
Default Re: Rear Disc Brakes & Wheel Wobble
How did you convert to rear disc brakes and how much did it all cost, anyway it could be your axle shaft, my dad had the same problem the tire was wobbling bad but he couldnt feel it changed the shaft and it was no more. Plus the was a easy uninstall/install.
You may not post new threads
You may not post replies
Similar Threads
rear disc causing wheel problem JERRY66SS Transmission & Driveline 1 Nov 1st, 04 6:13 AM
4 wheel disc brakes... Crazyhorse Brakes, Suspension & Steering 6 Oct 23rd, 04 9:04 PM
Poor Man's Rear Disc Brakes JKP Brakes, Suspension & Steering 16 Oct 7th, 03 9:22 AM
Disc Brakes at Rear Wheels for 71 Chevelle carsverboten Transmission & Driveline 0 Oct 19th, 02 12:11 AM
4 Wheel Disc Brakes Anyone? sam 1999 -- 9 Nov 8th, 99 11:32 AM
