Oil weight for drag racing/street use - Chevelle Tech
Auto Insurance
Old Jun 7th, 05, 2:50 PM
Steves65 Steves65 is offline
Question Oil weight for drag racing/street use
Can someone give me an idea of what oil weight to use following break in? Huntville racing (built my shortblock) suggested a 20/50 non-synthetic oil until break-in but didn't really have an opinion after that.
I am currently using Lucas 20/50 race oil. I would like to stay with Lucas but I am wondering if I should run a 10-40 wt. Thanks
Steve
Track Manager, Redding Drag Strip. My Street/Strip 65 Chevelle 1/4 Mile:11.61@116.03MPH with a.0221 reaction and a 1.603 60ft MY: album http://community.webshots.com/user/steves65
Old Jun 7th, 05, 2:55 PM
mr 4 speed mr 4 speed is offline
Default Re: Oil weight for drag racing/street use
I use 10W40 in the warmer months,and 10W30 in the colder months in my 70 SS
..theres no reason to use 20W50 in a new motor IMHO
Old Jun 7th, 05, 2:58 PM
427L88 427L88 is offline
Gold Member
Gene
Unless Huntville Racing built the engine with "race-type" internal clearances, which if they said 20-50 would be my guess. If the motor has 'nominal' clearances of say >00175 to .00250 on the rods and similar on the mains, then lighter would be better. Ask the builder how tight the motor was built.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
Old Jun 7th, 05, 3:01 PM
It gets to be in the 90's a lot here this time of year and I expect the air temp to be in the upper 80's at the track.. so I'll go with the 10-40
Is there a performance loss in the heavier weight oil??
Steve
Old Jun 7th, 05, 3:19 PM
71454Chevelle 71454Chevelle is offline
Darren
Send a message via ICQ to 71454Chevelle
After a good break-in period (maybe a thousand miles or so to get the rings seated good) I would use Mobil One 10w30.
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
  #6
Old Jun 7th, 05, 6:05 PM
1968 hot rod 1968 hot rod is offline
Bob
after breakin 0-30 Mobil 1
68 malibu 402 cid w/iron ret ports
10.28@131.78 1.47 60ft so far
10.11@132.3 1.452 60ft more to come!
Support our Troops!!!
  #7
Old Jun 7th, 05, 7:30 PM
orange2 orange2 is offline
I run 15/40 diesel oil, supposed to have much more sulfer?(I think) I figure if a semi my friend has can have over 25000 hrs on it and not need rebuilt the diesel oil must be good at what it is supposed to do.
71 z-28 454, 4 speed, 11.27@123mph
  #8
Old Jun 7th, 05, 7:35 PM
494GOAT 494GOAT is offline
I have run Mobil 1 15W-50 for years. Pretty reasonable price at Walmart. Clearances are around .0025"plus. I Know I lose some HP over lighter weights but the piece of mind is worth it. I agree that you need the machinist to tell you what the clearances are. If they are very tight then a lighter weight would be better. A friend with an 800plus HP 498 Hemi gained close to 30HP on the dyno from changing from 20w-50 to 0w-30.
494GOAT
65 GTO 494cid 674HP/622TQ . Don't hate me cause it's a PONTIAC. We are like cousins, right?
  #9
Old Jun 7th, 05, 8:59 PM
Gazzer Gazzer is offline
Team Member
I run 20W-50 Valvoline Racing Oil and have never had a problem.
Pretty mild temps here
Gaz
My 69 Triple Black SS
Front Right
Engine
My Business Card
95 Harley FLHR
Gaz,Mindy & the Bike
  #10
Old Jun 8th, 05, 11:01 AM
engineguy engineguy is offline
Bill R
Steve,
I am 'old school' believer in straight weight oil. My recommendation is straight 30W, or if you prefer multi-viscocity then go with 10-30 (my preference is Valvoline) and see how your oil pressure holds up when the engine is warm. 20-50W is too thick for any application, especially a new engine, in my opinion.
To answer your question, yes high viscocity oil will use up some horsepower - but not a whole lot. Think of the difference of stirring molassis as compared to stirring water. Now the volume of open space between the oil pump gears and is not very much, so the drag won't be very great. But the force necessary to transfer the oil through the pick-up screen, tube, etc will be significantly greater with the higher viscocity oil.
Bill
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (20+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
  #11
Old Jun 8th, 05, 12:09 PM
Keith Tedford Keith Tedford is offline
Keith
Our old 427 got beat on for upwards of 200K miles. It saw 6500 so many times that I wouldn't even hazard a guess. All we ever used was 10W30 oil. Whatever name brand that was being sold at the local stores would do. The oil got changed regularly along with a Delco oil filter (3000 miles). When I tore the engine apart, the pistons slid out of the bores without the need for a ridge reamer and the bearings still looked good. I've found Mobil 1 definitely makes cold weather starting easier, but these cars aren't out then anyway.
  #12
Old Jun 8th, 05, 1:40 PM
69ttop502 69ttop502 is offline
Bill
I think you might want to use an oil based on your application. Are you running a flat tappet cam or a roller? My engine builder advised me to use a 20W/50 with plenty of Zinc as I am running a pretty big solid flat tappet. Diesel oil is good in this application. If you are running a mild hydraulic roller, a light weight oil would be fine. But be aware, many of the well known synthetics of today do not have Zinc, so would not be as good in a flat tappet situation.
  #13
Old Jun 8th, 05, 4:12 PM
chevydog66 chevydog66 is offline
Jason
Royal Purple 10W30 makes good hp.
2 wrongs don't make a right but 3 lefts do!!
http://www.cardomain.com/id/chevydog66
66 Chevelle Malibu 406ci sbc 4L80 all motor 11.12 @ 120mph, 1.50 60', 3440lbs.
72 GMC Super Custom 1500, airride, 6.0 LS motor/4L65 trans.
96 Chevy Silverado Z71
  #14
Old Jun 9th, 05, 12:18 AM
sorry, zinc, not sulfer.
  #15
Old Jun 9th, 05, 10:44 AM
thunderstruck507 thunderstruck507 is offline
Kevin
My dad and I have always run Valvoline 10w-40, I've switched to Royal Purple 10W-40 and he will do the same once his big block is built and broken in
1971 Chevelle SS clone
head/cam ls1, 4l60e, 3.42 12 bolt
11.67@115mph, 1.71 60ft
Chevelle Tech > General Tech Area > Performance      Current Topic: Oil weight for drag racing/street use
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Stock volume oil pump with direct lube solid lifters ?? HPseeker Performance 22 Jul 21st, 06 9:25 PM
Fuel Pump Oil Leak Brad Engine 15 Apr 19th, 06 6:44 AM
Oil leaks and high oil pressure MonteCarloMark Engine 3 May 19th, 05 5:13 AM
race car oil brand and weight phantom Performance 6 Apr 17th, 05 11:13 AM
Milky oil.....help! (long) IROCJOE Engine 10 Apr 11th, 05 11:04 PM
