Stripped oil drain plug: how to get it out - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Jun 3rd, 05, 10:36 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
Default Stripped oil drain plug: how to get it out
I was changing the oil in the wife's daily driver. When I put the drain plug back in it never snugged down and now it spins but won't loosen or tighten. I need to get it out so I can replace it with an oversized one. I tried prying on the edge with a screwdriver while I turned it in the hope it would catch on one of the remaining threads and turn out of the hole but no luck. How the heck can I get it out?
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Jun 3rd, 05, 10:50 PM
71350SS 71350SS is offline
Default Re: Stripped oil drain plug: how to get it out
Rich,
the screwdriver thing will work if you use 2 screwdrivers to lift it out towards you as you turn the plug,sorta using the drivers as a wedge.
John
71 El Camino SS
406 SBC M21 3.31 12 bolt
Old Jun 3rd, 05, 10:55 PM
Super Mod
Rich
I'll try that in the morning. The sealing washer is really soft aluminum so I know I'll be able to chip it out of the way so the screwdrivers can get under the plug bolt well.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Old Jun 4th, 05, 12:40 AM
pauly383 pauly383 is offline
Send a message via AIM to pauly383 Send a message via MSN to pauly383 Send a message via Yahoo to pauly383
If its got a head a wrench or socket fits on , couldn't you grip it with vise grips and pull while turning ?
Paul , 70 malibu , the sad had kids slooooow build
99 Vortec Sub , 03 Impala , 83 K5
Old Jun 4th, 05, 12:53 AM
So let me guess,soft aluminum washer with a stripped drain plug.Is it a Honda?
John
71 El Camino SS
  #6
Old Jun 4th, 05, 1:39 AM
harleighguy harleighguy is offline
Rob
Talking Re: Stripped oil drain plug: how to get it out
Careful with the Honda jabs... They provide me $$ to pay my bills... If it's stripped out, then someone OVERTIGHTENED it! All the aluminum pans only take 29LbFt of torq on that crush washer~ Watch out for all the Walmarts and other FAST oil change joints with the calibrated arm on the wrench torq.
'65 Maliblue 406SBC/PG TC #811
'97 HD Softtail Springer
'02 FORD Ranger FX4 Level-II 4x4
'05 Civic Si (had to due to gas prices)
'SFC, U.S. Army RETIRED (Feb 02)
  #7
Old Jun 4th, 05, 9:06 AM
Keith Tedford Keith Tedford is offline
Keith
I've cured similar situations by using visegrips or a pipe wrench to turn the bolt while using the blade of a big screw driver for the tools to ride up on as you turn them. With Chevy engines there is a nut welded to the inside of the pan. If the weld were to break, pan removal would probably be the only way to get things apart. Have fun.
  #8
Old Jun 4th, 05, 2:47 PM
Buzzbomb Buzzbomb is offline
Roland
Nevermind, I misread the post. You have it on, it just won't tighten. I am sure the screwdriver trick will work...
"The man who lets a leader prescribe his course is a wreck being towed to the scrap heap."
-Ayn Rand
  #9
Old Jun 4th, 05, 9:44 PM
Super Mod
Rich
Yes it's a Honda. The two screwdriver method finally allowed me to get it out.
We've owned it for 6 years so if it's been overtightened it's my fault. But in my defense, the entire time I've owned it the plug bolt has been hard to turn even when not snugged down so I suspect the threads were damaged when I got it. The new one was tight to screw in all the way too so the nut welded into the pan may be somewhat damaged too.
I went to the parts store and bought a replacement plug and an oversized plug. The stripped threads were on the plug only and the replacement worked fine. I'll keep the oversized one handy in the event I need it in the future. The car has 165,000 on it so it's had it's share of oil changes.
Now if I can just figure out where the darn thing is leaking so much oil. It appears to be coming out at the front (side?) of the block near the timing belt and just below the head. It's not the valve cover leaking but it is oily just below the valve cover.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
  #10
Old Jun 4th, 05, 10:06 PM
BillK BillK is offline
Super Mod
Mr Bill
Rich,
I think the Hondas had a problem with the cam seals coming out and leaking. There is a fix with a new seal and a bracket to hold it in place. Either PM me or post the exact year, model, and engine size here and I will look it up for you. if its the cam seal you need to change it before it soaks the belt, belt breaks or slips, ...... bent valves etc etc.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
1984 Buick Riviera - original owner (Wife's car)
Team Chevelle #100
  #11
Old Jun 5th, 05, 12:18 AM
Super Mod
Rich
Originally Posted by BillK
Rich,
The leak is getting pretty severe so this makes some sense.
It is a '93 Prelude Si. It has the 2.3 dohc engine (not the 2.2 V-Tech). I haven't had the belt cover off yet but it does look like the oil could be getting inside the cover and if so, that's bad news. Looks like it's time to go further in debt on this thing (timing belt, might as well do the water pump while I'm in there, valve cover gasket, alternator and a/c belts).
Seeing where these seals are, can I change them without pulling the cams? It looks like they are right behind the cam drive gears but that's all I know.
Maybe I should get up early and pull that top belt cover off and see if it's oily inside.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
  #12
Old Jun 5th, 05, 5:47 PM
Rich,Good to hear that the drain plug was an easy fix.
Harleighguy,My daughter has an 97 Accord.I wasn't trying to jab at Honda,in fact they're great cars IMO.Just pointing one of their weak spots.Yes there are alot of ham fisted techs oil change techs out there but it seems the Honda's drain plug is easier to damage than most.Its Ok though, they're strong points outweigh most everything else.
John
71 El Camino SS
  #13
Old Jun 5th, 05, 9:29 PM
Hi-po SS 454 Hi-po SS 454 is offline
Richy Rich
Send a message via AIM to Hi-po SS 454
Rich, if you have not changed the timing belt yet, your way past borrowed time and are waiting for an engine destruction. Your belt is suppose to be changed every 90 thousand miles. And of course when your in there you change the water pump plus others things that have been mentioned
Rich
71 SS MJ 468" 570 HP 608 Torque Hyd Roller M22W (autogear) Muncie 4 sp 12B 3.55 posi...
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
https://www.youtube.com/watch?v=VzkB7RTVDUc
  #14
Old Jun 6th, 05, 8:12 AM
ss3964spd ss3964spd is offline
Team Member
Dan
Send a message via Yahoo to ss3964spd
I feel your pain Rich. My '90 Accord with the 2.3 leaks oil as well - just haven't investigated where exactly it's coming from. I've thought that front crank seal was the culprit but perhaps it's the cam seal and the oil is just running down - making it appear as though it's leaking lower. Been leaking for quite some time - needs a quart about every two weeks.
No complaints though - 162K and the original alt just went bad recently followed - naturally, by the 5 year old battery.
By the way, Honda says to replace the aluminum oil drain plug washer each time you change the oil. Apparently they will start to deform from repeated loosening/tightening. I just inspect mine each time - replacing it every 4-5 OC's.
Dan
Awww, fer cyrin out loud, it's that IMPALA guy again.
If I recall correctly my memory is excellent. My ability to access it is not.
SS 396 4sp
  #15
Old Jun 6th, 05, 8:39 AM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
I thought those motors were non-interference type. No chance of piston damage if the belt lets go...
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Stripped oil drain plug: how to get it out
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
RADIATOR DRAIN PLUG LOCATION 2005 Malibu SWEETTOOTH Chevelle Tech 5 May 14th, 05 12:50 AM
coolant drain plug on block Tokyo Torquer Engine 8 May 10th, 05 10:11 PM
Oil galley plug question dude67 Performance 1 May 5th, 05 11:58 AM
drain plug robert defalco Transmission & Driveline 1 Feb 16th, 03 10:09 PM
b/b oil pan w/center drain plug ray 2001 4 Aug 8th, 01 10:56 PM
