Brake Conversions Tech info on converting from drum to disc
Old May 22nd, 05, 9:48 PM
smithp29 smithp29 is offline
Default Disc brake conversion
I have a 1966 chevelle SS and i would like to convert brakes from drum to disc.I was told if i put a booster on i will have to change the steering column.Can any one tell me what it will take to get this done and maybe a good place to buy conversion kit.
Thanks Paul
smithp29<br />paul.smith1@mchsi.com
  #2
Old May 23rd, 05, 1:28 PM
JJ67SS JJ67SS is offline
John
Default Re: Disc brake conversion
I'm looking going from drum to disc using the Ground Up package for my 66 too - look here... http://www.ss396.com/pdf/newchevelle/41_48.pdf page 43. The kits FDISC-1 seems to come with everything you need - front & rear - including all new lines & flex hoses.
Additionally, you can get the rotors drilled and slotted FCDR-1 $179 or cross-drilled FCDR-66 $279 (not sure if that price is for 2 or 4 though...)
If someone else has opinions on this kit or other options, chime in. I'm trying to get the most bang for the buck
Old May 24th, 05, 9:56 PM
Steves65 Steves65 is offline
Check out Stainless steel brake corp. I used their kit on my 65 and went 4 wheel disc and also added power brakes. The kit was rather inexpensive and went on with no trouble at all. Pics are on the link below.
Steve
Track Manager, Redding Drag Strip. My Street/Strip 65 Chevelle 1/4 Mile:11.61@116.03MPH with a.0221 reaction and a 1.603 60ft MY: album http://community.webshots.com/user/steves65
Old May 24th, 05, 10:39 PM
jocww jocww is offline
ive never heard of people having to get a new steering coloumn be4 i mean it sits alot higher up there like 4 inches i dont see anyway for it to interfere with the steering
65 elcamino painted candy red aero hood scoop. Powered by a blown small block and 4 spd, stoped by 12in discs for you myspace people Girlscuddlebug69
Old May 26th, 05, 2:35 PM
NiteOwlNY NiteOwlNY is offline
-Allan-
Speaking of Ground Up, I'm looking to order their system for my 68, has anyone used the parts they supply and how did the job go? There's a lot of places out there selling disk brakes kits and Ground Up's price seems to be one of the best...
  #6
Old May 26th, 05, 3:40 PM
Olle Olle is offline
Team Member
I asked the same question about a year ago, but didn't get any replies at all so I ended up buying from an eBay seller. His eBay id is Whitemanford, e-mail address: ride34@aol.com. Send him an e-mail, I'm sure he can beat Ground Up's price. He was very quick to reply to my questions, and delivered promptly. I'm happy with the parts I got, especially considering what I paid. I'm thinking I really should post a review in the new forum, but for now you can PM me if you need details.
1969 Malibu in progress
  #7
Old May 26th, 05, 5:20 PM
John
Thanks for the e-mail address, I'm contacting them now...
  #8
Old May 27th, 05, 2:56 PM
Herb Herb is offline
Team Member
JJ, there's been a lot of info on drilled and slotted rotors on this site. Most of it negative. Unless you're going for the looks, the functionality doesn't warrant using them on a street/strip machine. In fact, it can have negative effects. You might want to do a search.
Herb Sr
'67 Coupe (frame-off)
489BB/M20/3.73 Eaton posi
http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG
.com
  #9
Old May 28th, 05, 3:31 AM
John
Yeah - I've heard good and bad. In a nutshell - Good is that the slotted & drilled are supposed to keep the rotor cooler. Bad is that they seem to help warp the rotor faster. I'm headed with the stock ralley rims so they will be VERY hard to see - not going for looks - going for that stopping power.
With my budget wielding out of control I may have to drop the drum to power disc conversion for the time being and settle on 4 new drums, with drum rebuilds and a dual master cylinder until more dollars arrive in the future
  #10
Old May 28th, 05, 6:28 PM
POWERBRAKEBOB POWERBRAKEBOB is offline
If Your Car Won't Stop When The Brakes Are Cold, Drilling The Rotors To Cool The Brakes Doesn't Work, And Actually Loses Friction Surface. If You Need More Stopping Power, More Valve Cover Clearance, Or Your Engine Is Low On Vacuum, Check Out The Hydroboost System. It Runs Off Of The P/s Pump, And Needs No Vacuum. You Can Run Any Wild Cam You Want, And These Even Will Clear, And Stop The Giant 572 Engines. There Is An Installed Photo On A Blown 454 Chevelle With Hydroboost At Powerbrakeservices.com Click On "company Info" To View. Also There Is A Nice Article On The Hydroboost In The July Issue Of Rod And Custom. These Things Work! They Are Smaller Than Even The 7" "off Shore" Booster, And Put Out Up To 2000psi. No Vacuum Pump Needed, No Vacuum Tank. We Use Stainless Braided Hoses For Most Installs. Brake Problems Over. 800 504 1060
64 EL CAMINO FIRST 327 (365HP) EVER BUILT. FEATURED IN APRIL 64 HOT ROD MAGAZINE, AIRHEART DISCS, HYDROBOOST ADDED 1984. WAS OWNED BY ERIC RICKMAN, HRM PHOTOGRAPHER, 1968 SS427 425HP, 4 SPD ser. no. 18, 1991 TURQ ZR-1, BLOWN 482 c.i. 409 FEB 1982 SUPER CHEVY
  #11
Old May 31st, 05, 10:27 PM
AMBUSH904 AMBUSH904 is offline
Check out the CCP kits,ebat link is
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4550118537
they come with everything for all four wheels including drillled and slotted rotors for 1,500.00 You can see the at my website on the blue car > www.camaromuscle.com
  #12
Old Jun 2nd, 05, 11:39 PM
chev702 chev702 is offline
1,500.00 Your Cracked In The Head I Wouldn't Pay 1,500.00 For 4 Wheel Disc Brakes If I Never Had Them. Why New?? Get Inventive Like Back In The Day Where You Swapped Parts That Fit,That Is The Trouble These Day"s Everybody Has To Have The Perfect Applacation Work On It Get The Disc Off Another Car And Re-Vamp Them To Fit Your Car. Holy Cow 1,500.00 How Do You Justify A Price Like That For Just A Vrake Set Up Even If You Started Out With A Frame On A Race Car You Could Most Likely Do Better And As For Bear Brakes Forget It, I Guess I Am To Much Old School, My 70 Stops On a Dime With My Old Drum Brakes What Is The Big Deal On The Old Corvette Brake System Anyway?? In This Day And Age Just How Fast You Plan On Going?? And For How Long?? Your Not Nascar You Have A Beautiful Car Why Race The Crap Out Of It And And If You Care About Your Car And You Putt Around How Much Braking Power Do Ya Need?? I Think Alot Are Putting Them On For Braggin Rights I Don't Understand The Big Deal?? If Your Runnin The Indy 500 YES get Disc But For A 1/4 Mile ?? What For?? It"s Crazy Just My Opinion
  #13
Old Jun 3rd, 05, 11:42 PM
Resto67-396 Resto67-396 is offline
Paul -
I have a 67 and just received a conversion kit in the mail this week from Ground Up Restorations. It was very well packaged, complete, and looks high quality at a reasonable price. If you like I will keep you updated about my progress in this thread.
Regards.
HG
1967 396 Chevelle
1969 RS Camaro
1963 Ford Falcon
1989 K5 Blazer
"The good old days are happening right here right now"
http://www.chevelles.com/showroom/Resto67-396/
  #14
Old Jun 4th, 05, 12:07 AM
John
Updates would be appreciated, though because of a budget (and me having to work to one) I may have to forgo the disc brakes. Looks like I'll refurbish the drums and update to a dual master cylinder...
  #15
Old Jun 4th, 05, 4:20 PM
Team Member
Aw yeah, drum brakes is the only way to fly... wonder who's "cracked in the head"? For those who are a bit more safety minded, I just posted a review of my disc brake kit in the review forum. Would be interesting to see reviews of other disc brake kits as well.
You may not post new threads
You may not post replies
Similar Threads
Front disc Brake Conversion $$$ Questions stavros7a Brakes, Suspension & Steering 10 Jul 24th, 09 1:01 PM
my disc brake conversion tips- stock A body bhawk Brakes, Suspension & Steering 10 Nov 8th, 08 1:13 PM
Can I use my Drum Spindles for a disc brake conversion? JR67 1999 -- 17 Jan 30th, 08 10:02 AM
Disc Brake Upgrades--Jury Pool Statements 2 Ike Brakes, Suspension & Steering 3 Dec 26th, 07 1:15 PM
Disc Brake Upgrades--Jury Pool Statements Ike Brakes, Suspension & Steering 7 Jul 11th, 03 6:15 PM
