| Chevelle Tech Current Topic: 70 Combination Valve picture | ||
| Brake Conversions Tech info on converting from drum to disc |
Anybody out there have a picture of a Combination valve (installed on the car) so I can see exactly where it goes?
Car is a 1970 going from manual drum/drum to power disc/drum. I pulled the old distribution block out this past weekend and it was held on by one bolt. The combination valve I have going on has two (think it was off a '71). Any help/pictures/good verbal description would be appreciated. Thanks, Chris
70 Malibu And it is staying that way.... with a few minor mods... |
#2
Chria
I will check if I have a pic, but I am not sure it help. The new valve you have got has not the same bolt pattern. So Far I have not been able to get a bracket for the new valva, CPP says "this is a problem" and recommend me to build something myself. If you find a bracket for sale somewhere, please let me know Hans
Camino + Eldorado |
Hi again Chris
I think I have found the part I need, www.inlinetube.com offers a bracket which hopefully will fit. Part Number - BRK-04 1971-72 GM A-body Valve Bracket $22.00 Look under New products and you will find it. To me it looks correct, but to see is to believe Hans
Camino + Eldorado |
Thanks Hans!
That looks like it will work perfect. Pretty cool website to boot. Woodman
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Internal Lockup Question | onabudget | Transmission & Driveline | 31 | May 24th, 05 9:02 AM |
| Button on combination valve?? | Black69 | Brakes, Suspension & Steering | 3 | Mar 14th, 05 11:47 AM |
| Combination valve question | Sixties Guy | Brakes, Suspension & Steering | 6 | Aug 4th, 03 7:02 PM |
| 1970 Metering Valve - front brakes will not bleed - valve seems stuck.... | SS454JC | Brakes, Suspension & Steering | 5 | Jun 9th, 03 11:12 AM |
| POA Valve Diagnosis | Gokou | Heating & Cooling | 12 | Aug 1st, 02 2:25 PM |
