How much lift c'an a stock BB spring take - Chevelle Tech
Auto Insurance
Old May 11th, 05, 12:31 AM
accontrol accontrol is offline
Question How much lift c'an a stock BB spring take
How much cam can a stock 454 spring ( 049 ) head will be able to handel ?
will it be able to handel 562 or 510 ???
i understand if they are all set up at the same level of resistance it
better ??
Old May 11th, 05, 6:28 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
Default Re: How much lift c'an a stock BB spring take
The springs will handle .550 - .560 (hyd flat tappet <6000 RPM). But the guides will need trimming for retainer/guide clearance over . 550 ( .540 to be safe). Besides, the stock heads flow well but level off at .500 with the stock valve sizes and factory machining in the bowls anyway.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old May 11th, 05, 8:21 AM
pdq67 pdq67 is offline
Guest
Paul
Smile Re: How much lift can a stock BB spring take
I think stock lo-po springs are only good for about .500" lift MAX. and the 350/360hp springs are good for some higher as are the .500" net lash 375/425hp solid cams springs.
Heck, the lo-po cams only lift like .398"/.420 " or so don't they?? And the 350hp cam like .460"/.480"?
I need to get my "brains" out and check?????
pdq67
PS., run the springs you need for the cam and if you want cheaper ones that still will work, then check out Competition Products long spring list..
Old May 11th, 05, 9:53 AM
mr 4 speed mr 4 speed is offline
I've run the Crane 272H .515 lift and the the 302H .544 lift with stock BBC springs with no problems
Old May 11th, 05, 11:35 AM
thank this set of head is going on a tall deck 427 60over w the long rod
from Eagle and the new speed pro 190 dome forge piston i dont know the
amouth of cube this will give ,,??
but the 049 are the bigess 124cc chamber and also the bigest intake runner
and ex in cc for and oval port.
that what i was told ?
so a mild cam will make this a killer street motor
  #6
Old May 11th, 05, 1:24 PM
Guest
Paul
Smile Re: How much lift c'an a stock BB spring take
I strongly suggest that you run the springs that are recommended or a cheaper, same spec. spring.
And the only way to actually know head chamber cc is to measure them!!
Open chambered, large oval heads vary from as small as about 112/113 all the way up to at least 122 cc's.....
Or you are guessing at what your CR. calculates out at, imho!!
pdq67
  #7
Old May 11th, 05, 11:36 PM
Harold Sutton Harold Sutton is offline
Valve springs are the absolute worst place to cheap out. If, or should i say when, the spring gets weak it will pull the top off of the valve and you'll drop a valve a possibly lose the whole motor. Get the absolute best valve spring you can afford even to the point of waiting to finish the project until you can buy good springs. I recommend Isky or Manley Nextek if a roller or Isky, if it's a flat tappet or hydraulic and good keepers and locks. The major cause of valve failure is weak springs.
  #8
Old May 12th, 05, 1:21 PM
Guest
Paul
Unhappy Re: How much lift c'an a stock BB spring take
I guess that leaves out the great old, el-cheapo, Z-, (-142) and LT/ZZ or whatever the later stock springs are that are dirt cheap, at least for SB motors.
AND I wouldn't run the stock springs that come on 454 P/U motor's -781 heads on a bet!!...
pdq67
  #9
Old May 12th, 05, 2:49 PM
Hi pdq67, I absolutely wouldn't use any Chevrolet spring as i've found them to fatigue rather quickly. The ZL-1 retainers are O.K. but the springs and valves aren't very good. If a good spring with really good seat pressure is kept on the heads all the other parts in a big block are real strong. A friend of mine dropped a valve in my old 454 and tore the heads up pretty good. I haven't used Chevy valves or springs since.
Chevelle Tech > General Tech Area > Performance      Current Topic: How much lift c'an a stock BB spring take
Human Verification
Similar Threads
big block stock rocker arms w/.560" lift? Rad Racer Performance 3 Dec 10th, 04 6:18 AM
part number help for bbc ddeennis Performance 2 May 6th, 04 8:19 PM
SSM/Jegster lift bars vs coil spring traction bars Big James 4XL Performance 11 Apr 20th, 04 11:29 PM
HELP - Frt Springs pages67 Brakes, Suspension & Steering 2 Apr 19th, 03 11:56 PM
Anyone installed lowering springs on their early Chevelle or El Camino? Bill64EC 1999 -- 5 Mar 24th, 99 3:44 PM
