Replacing upper control arm bushings - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old May 2nd, 05, 6:41 PM
4MyChevelles 4MyChevelles is offline
Send a message via AIM to 4MyChevelles Send a message via MSN to 4MyChevelles
Default Replacing upper control arm bushings
The bushings that sit in the rear housing ..how difficult are they to replace with the rear in the car ? 66 Chevelle
I want to replace the arms and they come with the bushings installed
the ones in the housing ,,well you know they can't come installed.
This job would be done on the ground with a creeper and no air tools
Thanks for your input
There is no Replacement for Displacement
I think it's fixed
http://mysite.verizon.net/vzeecr2m/
Old May 2nd, 05, 6:58 PM
Xtreme70SS396 Xtreme70SS396 is offline
Mark
Default Re: Replacing upper control arm bushings
That's how I did mine. A big hammer and socket to match the size of the bushing worked fine for me. Not ideal, but not really that difficult.
Used a big drill, slowly through the rubber to remove the existing bushings.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Old May 2nd, 05, 7:09 PM
Ok so removal is the hard part then ?
why a drill?
Have to rip them apart to get them out ?
I think it's fixed
Old May 3rd, 05, 6:27 AM
6t7gto 6t7gto is offline
you have the top control arms out.
disconnect 2 shocks, 2 bolts on lower arms, 1 rubber brake hose, parking brake cable,and a driveshaft.
put the rear on a 4-wheel dolley.
and you now have the rear out from under.
makes the job real easy.
david
Old May 3rd, 05, 8:35 AM
Mark
The rubber is impossible to just force out. Drilling through the rubber frees up the center sleeve for removal, then the outer sleeve can be forced out. Some people burn it out, but I've found with a drill it only takes a few minutes.
INSTALLATION is the hard part IMO, removal was pretty easy.
Mark
1970 SS396
634 HP @ 6000rpm
ProSystems SV1
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
  #6
Old May 3rd, 05, 10:20 AM
OLDED OLDED is offline
Team Member
Ed
You can also use a ball joint press to push out and push in and not even need the Ford tool to hit with. (after you get the housing out on the floor) OLDED
OLDED - It's STOCK if it's made by GM and it fits!
*65 Elky, Gen VI 496 BBC, TH400
*59 Vette, 283/270 hp. T5 5 spd., 4:11 posi.
*Harley - 06 Street Bob
*Life Member - Team Chevelle & Team ElCamino
*Peach State Chevelle Member
*Retired June 1, 2014****
  #7
Old May 3rd, 05, 2:07 PM
here's a home-made tool.
1/2 way down the page.
http://forums.performanceyears.com/e...1108#629101108
david
  #8
Old May 3rd, 05, 2:47 PM
1hot67 1hot67 is offline
Michael
david
The method mentioned in the last post at the bottom of that thread is the one I used. Worked like a charm.
1967 Chevelle SS
Chevy High Performance 12/06
1997 Camaro Z28 LT4, 11.24 @ 119.34
2007 Corvette Z06
All cammed, two stroked, and one stalled.
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Replacing upper control arm bushings
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Rear Upper control arm bushings? oregonchevelle Brakes, Suspension & Steering 1 Jan 8th, 05 11:00 PM
Installing springs and shocks djshakes Brakes, Suspension & Steering 17 Aug 9th, 04 10:52 AM
Front Lower Control Arm Bushings MrAbody Brakes, Suspension & Steering 2 Apr 8th, 04 7:32 AM
Upper Control Arm Bushings ric902 Brakes, Suspension & Steering 1 Aug 4th, 03 4:47 PM
Upper control arm bushings on rear axle jodysss396 Brakes, Suspension & Steering 5 Apr 2nd, 03 1:35 PM
