Brake Conversions Tech info on converting from drum to disc
Old May 2nd, 05, 9:59 AM
ZIGGY454 ZIGGY454 is offline
Question Will 71 Chevelle Discs & Spindles Fit A 67 Chevelle ??
Guy's;
Will a complete set of disc & spindles from a 71 fit in a 67 ? The 67 now has power drum, I believe I can reuse the booster but I know I will have to change the master cylinder. Any brake line issues with the master cylinder ? I know I will have to change the front lines to the calipers. Can I use the 67 spindles and just instal the 71's backing plates & caliper brackets ??
Any and all input is most welcome !!!
71' 850 Dbl pumper Holley fed 454 Chevelle SS ,TKO Tremec 5-speed, with 3:31 gears. You can never have too many HP's !!!!
  #2
Old May 2nd, 05, 11:14 AM
YenkoChevelle69 YenkoChevelle69 is offline
Shahreyar
Send a message via AIM to YenkoChevelle69
Default Re: Will 71 Chevelle Discs & Spindles Fit A 67 Chevelle ??
Yes it will.
1969 SS396 Monaco Orange
4 speed
12 bolt
489 big block
2003 Silverado SS
AIM= YenkoChevelle69
1969 Chevelle Quarter Panel Replacement
Old May 2nd, 05, 11:25 AM
Olle Olle is offline
Team Member
But you'll have to change the spindles. Discs won't fit on drum spindles.
1969 Malibu in progress
Old May 2nd, 05, 12:46 PM
Question Re: Will 71 Chevelle Discs & Spindles Fit A 67 Chevelle ??
Ok; Thanks for the replies guy's !!!! Question #2, will I have to change the upper control arm to the 71's ?? If not will I have to get custom upper and lower ball joints ?? Or will the 71's spindal just bolt in ??
Thanks again !!!
ZIGGY454
Old May 3rd, 05, 12:28 PM
BluEyesIDFN BluEyesIDFN is offline
They are the two-part spindles with the caliper adapter that bolts on, right?
If so, then they should just bolt on. Just be careful of the balljoint boots when seperating them unless you want to replace them.
  #6
Old May 3rd, 05, 1:14 PM
Team Member
Yes, I believe they'll bolt right in. One thing you might want to check is the bolts that hold the pitman arm to the spindle. From what I have heard they changed between 1967 and 1969, but the c/c should still be the same so you can use a bushing on the bolts.
  #7
Old May 4th, 05, 12:32 AM
I think you mean the steering arms, not the pittman arm. The pittman arm attaches to the steering box
But, on the bolt sizes, I believe you are right. They went from 7/16" to 1/2" at some point. You could make a shim to take up the slack, or just drill your steering arms to match the spindles.
  #8
Old May 4th, 05, 1:32 PM
Team Member
I can call them anything I want, it's a free country, isn't it?
You may not post new threads
You may not post replies
Similar Threads
Disc Brake Upgrades--Jury Pool Statements 2 Ike Brakes, Suspension & Steering 3 Dec 26th, 07 1:15 PM
Will Caprice discs fit a Chevelle? CRUZN68 Brakes, Suspension & Steering 9 Oct 9th, 04 3:33 AM
drum to discs on 68 chevelle? bubba68ss Brakes, Suspension & Steering 16 Aug 10th, 04 4:35 PM
'71 skylark discs work on '70 chevelle Hugh 1999 -- 13 May 15th, 99 3:43 PM
'71 skylark discs work on '70 chevelle Hugh 1999 -- 1 May 12th, 99 12:01 AM
