Brake Conversions Tech info on converting from drum to disc
Old Apr 20th, 05, 11:27 AM
66_427 66_427 is offline
Default 66 Disc conversion Ride Height Problem.
I inherited this problem when I bought the car. The front brakes were changed over to disc. I'm not sure what the spindles are off of, but when I bought new calipers, they matched up to ones for a 1970 chevelle. Here's my problem, the car sits too high in the front and the upper control arm geometry is extreme (sitting on snubber). It appears as though the spindle is shorter than original. Since I don't have an original to compare to, I don't know. The spring itself is the proper length. Is there any easy way to fix this? Can I get a trick ball joint to raise the spindle up off the lower control arm, thus lowering the height & correcting the geometry? I know they make such a thing for some GMC vans.
If anybody else has encountered this, please let me know. Any help is much appreciated.
Thanks.
  #2
Old Apr 21st, 05, 11:22 AM
Herb Herb is offline
Team Member
Default Re: 66 Disc conversion Ride Height Problem.
Wouldn't raising the upper CA be the same as lowering the lower? Raising the upper has some postive benefits with handling.
Either way, here's a ball joint that will do either.
http://www.scandc.com/
Someone else can verify this but, I don't think there is any difference in the physical height of the 68 - 72 A body spindles from the 66/67.
Herb Sr
'67 Coupe (frame-off)
489BB/M20/3.73 Eaton posi
http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG
.com
You may not post new threads
You may not post replies
Similar Threads
Front disc Brake Conversion $$$ Questions stavros7a Brakes, Suspension & Steering 10 Jul 24th, 09 1:01 PM
Rear disc conversion - 67' kxmotox247 Brakes, Suspension & Steering 6 Nov 24th, 04 6:06 PM
1971Chevelle Power Drum to Power Disc Conversion Problem Shannon Custalow Brakes, Suspension & Steering 5 Sep 9th, 04 1:23 PM
Disc brake conversion 66 to 71 or 72 Rich02 Brakes, Suspension & Steering 7 Aug 26th, 04 12:48 AM
uneven ride height Savdog 1999 -- 8 Oct 26th, 98 5:17 PM
