| Chevelle Tech Current Topic: Vinyl top how to? MartinSR? Anybody? | ||
| Register | Photo Ads | Blogs | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read |
| Body Shop Paint & Body Forum |
Alot of the cars I work on have vinyl tops, my upholtery guy usually installs these for about $200 labor plus materials but now doubled his labor charge to $400. I'd like to start installing these myself but have never attempted the job. I know of nobody else within 50 miles that would install these for me, it seems to have become a lost art
Can anyone here walk me through the installation process? Any books on the subject? I can't see it as being very difficult. My customers are at the mercy of the upholstery shop. Bob
| Sponsored Links | |
Advertisement | |
#2
I have never done one. I have pulled up a LOT of them off the quarters and around the rear window for repairs and glued them down successfully. But that the extent of my experiance.
What I have done, and what I have seen, it is not that big of a deal. But honestly, I think I would farm it out, mark it up a few bucks and leave it at that. Do things that you REALLY know and can make money doing.
Brian Martin 1965 Buick Gran Sport Convertible "Fan of most anything that moves human beings" |
Installing a vinyl roof, especially when done in conjunction with other body/paint repairs is a reasonably easy, straightforward job. The actual installation time should be about 2-3 hours. I have installed them by myself, but the job is so much easier if you have a helper.
Frankly, I wouldn't take a job of just replacing a vinyl roof that's not done as a part of body/paint repairs. There are way too many glitches and pitfalls, rust, molding/clip issues that can jump up and slap you in the face, but simply re-installing the vinyl after other body/paint work is pretty easy. If you would like, I can walk you through my way of installing the vinyl. Email me. |
Hey vettefella,I'd be interested in hearing them tips also.I have one to install on my elky soon.It's painted now,so after I get the quarters sanded and buffed out I'll be ready
[img]graemlins/waving.gif[/img] Rick |
Flywheel, you have mail...
#6
Vettefella, you've got mail, thanks
#7
Thanks vettefella,I may have some ???'s soon.I'm still working on getting the doors and fenders back on and lined up now.I haven't laid out the top yet so where the seams will need to go is still alittle fuzzy to me,and the double "u"
.One folded under and one folded up and into the folded under one???.That seems like it would be hard to do.It may easier when I lay it all out and see it [img]graemlins/clonk.gif[/img] [img]graemlins/waving.gif[/img] Rick |
#8
Flywheel or Vettefella , could you send me the info. on installing new vinyl tops ? Thanks,Mark --------------------------------------1968 Chevelle Malibu (Weekend Cruiser) 1969 Chevelle Malibu (Daily Driver)
#9
I would also appretiate a copy of the artical, i pulled my top off yesterday and am very disapointed in the prep before the otehr top had been installed. I cant wait to get another one on.
Charlie 72 velle It may be a rusted lump of steel but its MY rusted lump of steel |
#10
vettefella - Maybe you should just post it here! I'm interested too.
Thanks, Lee
230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads, MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB, PowerGlide, 5000 stall converter. 8.70@154 MPH My Projects Homepage: http://www.horsepowerracing.com |
#11
Guys, I emailed that to three people. If one of them would be kind enough to post it...??? I was having slow load problems yesterday and cleaned out all my cubby holes. In the process, I deleted the vinyl top procedure.
Badbob71 probably has the best copy. I had made a couple of minor additions from the other two. If no one has posted it within a day or so, I will retype it and post. |
#12
Here is my copy, you can reply with your additions if you want.
First, I assume you have an A body and the replacement top you are going to install is one that is commercially available from sources such as OPG, GroundUp, Yearone, etc. and is of the "better" quality. Additionally, when the vinyl tops were installed at the factory, it was done before the molding clips around the windshield and back glass had been installed. That is the best way to install replacement tops. Most upholstery shops won't/can't remove the clips to install replacement tops and that can cause problems a few years down the road. Further, when the tops were installed at the factory, they put four screws into the vinyl. One at the ends of the two seams front and back at the recess of the windshield and the back glass. It isn't absolutely necessary to do that on the replacement tops, but is advisable. Even the best quality vinyl will shrink over time. That's why it is best to install the replacement with the clips removed and to put screws into the ends at the seams. Installations procedures: Purchase at least two, preferably three spray cans of 3M Super Duty Trim adhesive. Do not attempt to use the "General Trim Adhesive". It may only require two cans, but if you aren't experienced in this procedure, you don't want to find yourself short of adhesive. Lay the new top out on a flat surface, preferrably in the hot sun or at least in a 75°+ environment. The lower the temp, the longer you must let it sit so that the packing wrinkles will be completely relaxed. Depending on the specific application, you may need to do two or four "seams". You may need to do seams at the "A" pillars and almost definately at the panel below the rear glass. These seams are best done after the major portion of the top has been glued down. If you've never attempted the installation of a vinyl top, you should get a helper if at all possible. Once the new vinyl has had a chance to "relax" the packing wrinkles, lay it over the roof of the car. Measure, double measure, triple measure exactly where the seams of the new top should go. Mark the roof of the car with a magic marker or whatever at the exact points where the seams should be. This will require stretching the vinyl into nearly the exact position that it will be once it is glued down. When you have determined the seam points, make sure that the top doesn't move from that point on. This is where a helper is so important. You can start from the front or either side to begin the glueing procedure. I prefer the front but it isn't a big thing. Carefully fold the new vinyl back onto itself approximately halfway of the top. Spray the adhesive moderately on both the vinyl and the roof on the car. If you haven't already determined exactly where the seams should be, you'd better do it now, because it's about to be too late to change your mind. Wait 3-4 minutes for the glue to begin to set, then fold the new vinyl into place. Don't wait the full time recommended on the spray can, otherwise you will have absolutely no latitude for error correction. Be absolutely sure that the seams are in exactly the positions you've marked, otherwise, they will be crooked/wavy after it's all over. At this point, don't be overly concerned about fit/glueing at the gutters or around the w's or rear glass. Those should be done last so as to make any minute corrections...if that is possible. Once the first half of the roof has been glued down, do the other half in the same manner, makng sure that the seams are exactly straight. When the major portion of the roof is glued into position, prepare to do any necessary seams at the A pillars and the rear panel below the rear glass. You probably won't have to do a seam at the A pillar, but if so, just follow similar instructions as the rear panel. The strip of vinyl for the panel below the rear glass will come as a separate piece. Trim the ends of the major roof piece to the approximate length necessary. The metal body seam is a good point to go by. Lay the rear panel strip out straight. Spray glue onto at least the first/last inch of the major roof piece and the rear panel strip. Fold about 1/2" on the major roof piece into about 1/2" of the rear panel piece. You will have a "double U" type of fit at that point. Make sure you have sufficient glue in the entire area and press the seamed portion down firmly until it sets. Glue the rear panel strip down to the opposite side. This is where it gets tedious. You must make a seam just like the one on the other side and when it is glued down, it must be flat wthout wrinkles. It requires some "fooling around" before the glue has time to set. Don't worry about getting glue on the outside of the vinyl. It can be easily removed when you are finished with lacquer thinner or other solvents/adhesive removers. Once you've glued down the major portions of the top including the A pillars and the rear panel, it's time to make sure the gutters and around the windshield and rear glass are properly in place. For the front and rear glass, simply pull the vinyl tight(it should already be properly aligned side to side and front to rear), spray glue on the edge of the vinyl and into the recess where the glass sits. Trim the vinyl so that it will go to the bottom of the recess. Press the vinyl into the recess. When you have it pressed down, cut small slots for the trim clip studs to peek through the vinyl. If you are completely replacing the studs, simply glue the vinyl down the smoothest you can, then install the replacement studs or screws with clips, whichever you are using. At the gutters, you should have already removed the chrome trim(if any) on the gutters. Spray glue liberally on the vinyl and into the gutter. Make sure the vinyl is glued firmly into the gutter before attempting to re-install the chrome trim on the gutter. At the sail panels and along the rear deck panel where the molding goes, make sure that it is liberally glued along the edges and preferrable fitted over the molding clip studs. The fit is very critical at these points. Remember that vinyl shrinks with age. If you cut it short, it will pull away from under the molding in a few months/years. Golly, I'm as tired as if I had actually installed a vinyl roof. Did I skip anything? If so, feel free to ask questions.
Dave 66/68/70 chevelles 55/57/61 belairs 69 70 71 72 novas 65 olds 442 LT1 T56 other money pits and projects |
#13
Just one thing that might be helpful...At the gutters, when the chrome trim has been re-installed, the vinyl should have been trimmed so that it fits underneath the edge of the chrome just barely...not so much that it goes over to the outside edge of the gutter rail.
#14
vettefella, You did a good job here. Everybody owes you a thanks- [img]graemlins/beers.gif[/img]
#15
Anything critical about smoothing the vinyl out and/or the amount of glue put on?
Thanks vettefella.... [img]graemlins/waving.gif[/img] Rick |
| Display Modes | |
