| Chevelle Tech Current Topic: Have power drum brakes...want power disc...what needs changed? | ||
| Brake Conversions Tech info on converting from drum to disc |
Can I use any of my existing factory components...booster, master cylinder? Or do I need to change EVERYTHING? Obviously, I will need to change spindles and proportion valve.
The car is is a '70 Malibu.
If you have a Comp Cams 288AR solid roller cam for a BBC and want to sell, please PM me. WWW.SOMERNITESCRUISE.COM |
#2
All I changed on my 69 elcamino was the master cylinder, the proportioning valve, used the stock drum spindles and got the baer front disk package. I think that baer makes their kit to fit the drum spindles but most others do not. So you might need new spindles if you get another kit.
If you want to use OEM style brakes, you can only reuse the booster. Don't know how much those Baer brakes are, but it's probably cheaper to buy a complete std disc brake kit but without the booster. BTW, doesn't hurt to change the booster on a 35 year old car either.
1969 Malibu in progress |
e-mail this guy for a quote on a complete stock type disk bake kit. Cheapest price I got.
RiDE34@aol.com
Herb Sr '67 Coupe (frame-off) 489BB/M20/3.73 Eaton posi http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG .com |
#6
tmino:
Do you have the p/n for the proportioning valve? ZO6 calps on a 1969 Chevelle. Thanks!
Hot Rodding: Turning Money into Noise When you don't know where you are going, any road will get you there - Will Rogers |
#7
The part number for the baer disk brake kit is #4301008 and the proportioning valve part number is #2608419.
#8
Thanks!
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 700R4 and 2004R Transmissions | G.M Transman | Transmission & Driveline | 81 | Jul 13th, 07 1:55 AM |
| 600cfm Edelbrock Carb MathReference -- Jetting, Jets, & Rods | hd99fxst | Engine | 5 | Nov 14th, 06 8:32 PM |
| Problem with Front Corvette & Rear Cadillac disc brakes SOLVED!!! | Theo | Brakes, Suspension & Steering | 12 | Jun 15th, 05 3:39 PM |
| Praise Dyno Brake and Master Power Brake Rear Drum Brakes | MAXX2 | Brakes, Suspension & Steering | 1 | Dec 8th, 03 4:36 PM |
| Need GM part number for Master Cylinder Cap Gasket - 1971-1972 with power disc brakes | elcamino72 | Restoration Corner | 5 | Jun 6th, 03 4:18 PM |
