Brake Conversions Tech info on converting from drum to disc
Old Mar 21st, 05, 8:46 PM
JohnnyRocket JohnnyRocket is offline
Default front drum to disc on a 66
Just need a parts list of what is needed for this conversion, would like to stay manual brakes. I want to know what I am okay with buying used/in a junkyard, and what is absolutely necesary to buy new. Thanks very much.
If you didn't build it, you don't own it.<br />one 66 malibu, about to be molested.
  #2
Old Mar 22nd, 05, 10:44 AM
Cam Sweet Cam Sweet is offline
Gold Member
Default Re: front drum to disc on a 66
Well, how much you do and how much you buy is really dependent on your budget. If I were to do it again, and I will, I'd....
1. Modify your existing spindles.
2. Buy from our sponsor the caliper brackets.
3. Buy from your favorite local parts house, rotors, loaded calipers and incidentals
( bearings, dust caps, nut, washer, pin etc)
If you are running 14 inch wheels and you don't want or can't modify your spindles, you can buy from our sponsor the spindle, caliper, gravel sheild kit for like $250. IF you are running 15 inch wheels the gravel sheilds look funny. IMHO
Brake lines and master cylinder are best bought new.
Hope this helps
Cam
Old Mar 22nd, 05, 8:35 PM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
do you have to buy a new master cylinder when going from drums to disks? and why is that? cant you just get a new prop valve.
also, do you have to use a powerbooster on disk brakes, or can you run it manual. reason why i ask is because, i can get some front disk spindles, and the stuff i need to do the swap from a buddy, but i just bought a new MC for drums a few months back.
aaron
71 chevelle 355, voodoo roller 282/290, Brodix IK 180, 300-36, 3310, MSD, 355's, and an M20.. 314whp/349wtq on a dynojet, 12.911 @ 105.6, 1.95 60ft
94 Trans AM GT... Corsa Catback, By-passed TB, 160* t-stat, descreened MAF, Moroso CAI, Vortec elbow, A4, 3.42's
http://s28.photobucket.com/albums/c209/ssclonelq9/
http://www.sloppymechanics.com/
Old Mar 22nd, 05, 9:33 PM
Tom's 68 Tom's 68 is offline
Team Member
Captain Morgan
aaron
one reason the disk MC is different is that you displace alot more fluid with the calipers and as your brakes wear the reservoir would empty much quicker
as for your master - just replace it
also (and this part I am not positive about) they don't make a disk MC with a pushrod that hooks to the pedal
as far as I know the MC's were only designed to run with the power booster
(again just letting you know I am not sure about the power booster part)
2211
Hello Howard, how's it goin' friend, next door neighbor, Oh yeah, get your F%^&*() jumbo jet off my airport!
Old Mar 23rd, 05, 4:52 PM
Aaron
ok thanks.
i think when i plan on doing the swap, that i will just buy all new parts (well calipers, mc, booster and such).
aaron
You may not post new threads
You may not post replies
Similar Threads
Front disc Brake Conversion $$$ Questions stavros7a Brakes, Suspension & Steering 10 Jul 24th, 09 1:01 PM
Problem with Front Corvette & Rear Cadillac disc brakes SOLVED!!! Theo Brakes, Suspension & Steering 12 Jun 15th, 05 3:39 PM
Factory front disc conversion Natural Born Killer Brakes, Suspension & Steering 1 Feb 26th, 05 10:25 AM
67 Front Disc set up questions DS67SS Brakes, Suspension & Steering 9 Oct 29th, 04 12:27 AM
Front disc swap using drum spindles.... AdamLym Brakes, Suspension & Steering 13 Jun 25th, 04 10:29 PM
