Brake Conversions Tech info on converting from drum to disc
Old Mar 20th, 05, 1:16 PM
Dr.Dell Dr.Dell is offline
Cool Modify drum brake spindles to fit disc brakes
Modify drum brake spindles to fit disc brakes.
The top mounting boss is to long on drum brake spindles. If it is cut down or machined down 1/2 to 3/4 inch it turns drum brake spindles to disc brake spindles.
My question is does anyone know for sure the exact amount that has to be removed?
I have heard .610 and also .750
Is either one correct?
Thank You.
  #2
Old Mar 21st, 05, 11:55 AM
Herb Herb is offline
Team Member
Default Re: Modify drum brake spindles to fit disc brakes
Good question. I'd also like to see before and after pictures of the mod.
Herb Sr
'67 Coupe (frame-off)
489BB/M20/3.73 Eaton posi
http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG
.com
Old Mar 21st, 05, 1:09 PM
Dean Dean is offline
^pudentane^
Unhappy Re: Modify drum brake spindles to fit disc brakes
Here are John's pictures
http://www.chevelles.com/showroom/Dean/Clinkage.jpg
http://www.chevelles.com/showroom/De...lleSpindle.jpg
Old Mar 21st, 05, 3:38 PM
Cam Sweet Cam Sweet is offline
Gold Member
I've done this modification several times. I found the amount to cut off different on all the spindles. I attached the caliper bracket to the lower mount, snug but not tight and then rotated the bracket up until it touched the upper pivot bolt boss and scribed a line. I used a hacksaw to remove the majority of the boss and a Bridgeport mill to machine them flat. The flats on the backside of the steering arm mounts are plumb to the axle centerline and parallel to the surface of the boss. Oh, BTW, this only pertains to 69 and later spindles. You can modify earlier spindles, it's just a little more work.
Cam
Old Mar 31st, 05, 3:49 PM
Olle Olle is offline
Team Member
Cam,
Don't you have to bore the boss and retap it too? I was going to do this myself, but decided not to after reading several posts here saying that the hole isn't deep enough after you cut the boss. Or do -69 and up have a deeper hole than the earlier ones?
  #6
Old Mar 31st, 05, 4:11 PM
Gold Member
Yes, 69 and up have the correct hole/thread. Pre-69 do require drilling out the hole and retapping for the 1/2" bolt. Also on pre-69 the steering arm mounting bolts are smaller diameter so the you need to fashion a shim to take up the slop in the caliper bracket hole.
Cam
  #7
Old Mar 31st, 05, 4:38 PM
John_Muha John_Muha is offline
Moderator
Hey You!
The later spindles seem to be drilled deep enough. On the 4 I cut, I did have to tap a little further with a bottom tap. However, the hole was deep enough to tighten the bolt into it.
Yo-ho Yo-ho a pirate's life for me.
  #8
Old Apr 1st, 05, 1:35 PM
Team Member
Cool I just got through changing to disc brakes, so I have a set of drum spindles left over. I might give it a try just for fun.
  #9
Old Apr 5th, 05, 11:56 AM
lemonice lemonice is online now
Talking Re: Modify drum brake spindles to fit disc brakes
hello,i have a 1969 chevelle, i would like to convert to disc brakes using the infomation you guys are talking about,but i am totaly confused. does anyone have a more detailed instructions for making my spindles work. i have the complete spindle assembly,roter,caliper off a 76 nova.exactly what do i do to convert.i am a mechanic and have all the tools i need. thank you. lance.
  #10
Old Apr 5th, 05, 4:50 PM
Gold Member
Well, Lance, I suspect that the spindle assemblies you have off of the 76 Nova classify as the "tall spindle" swap, of which I know nothing about. Your original drum brake spindles can be modified to accept the caliper brackets for a standard 64-72 A body disc brake setup. The brackets are available aftermarket from our sponsor, GroundUp fo like $95. The rest of the swap comes from your favorite parts house. I don't believe anything from your Nova setup is usable unless you do the whole tall spindle upgrade.
Cam
  #11
Old Apr 5th, 05, 8:45 PM
i guess i did sound a little confusing on my post. what i was trying to say is that i want to do the drum to disc swap using my exsisting drum spindles like they were explaning in the above post.i thought that since i had the 76 nova spindle setup, that i could use those rotors and calipers.
  #12
Old Apr 10th, 05, 10:40 PM
BillK BillK is offline
Moderator
Mr Bill
So,
Are you guys saying that there is no other difference between the drum and disc spindles ???? Has anybody had them side by side to compare ? I am thinking about switching to discs and that would sure make it nice since my original drum spindles have been bead blasted and powder coated. All I would have to do is put them up in the mill and carve away
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
  #13
Old Apr 11th, 05, 10:21 AM
Gold Member
That's it, Bill. Like I previously mentioned, I get the amount to knock off by seeing where the bracket would rest by swinging it up attached only by the lower mount. I hacksaw off the majority of the boss and then clean it up with the mill. I clamp the spindle down on the table with the backside of the steering arm mounting ears on the 3 side of a set of 1-2-3 blocks. Man, I really ought to snap a set of pics... I have another set to do for a buddy. Hope this helps.
Cam
  #14
Old Apr 14th, 05, 1:25 PM
after you do this what rotor do you use and what caliper do you use? thank you.
  #15
Old Apr 14th, 05, 1:34 PM
Team Member
68 - 72 parts will fit.
You may not post new threads
You may not post replies
Similar Threads
Can I use my Drum Spindles for a disc brake conversion? JR67 1999 -- 17 Jan 30th, 08 10:02 AM
Disc Brake Upgrades--Jury Pool Statements 2 Ike Brakes, Suspension & Steering 3 Dec 26th, 07 1:15 PM
Difference between Master Cylinder/Booster for Disc and Drum Brakes?? northern 396 Brakes, Suspension & Steering 12 Mar 11th, 05 5:58 PM
simple rear disc brakes FO_FDYFO Brakes, Suspension & Steering 6 Sep 2nd, 03 10:09 AM
Disc Brake Upgrades--Jury Pool Statements Ike Brakes, Suspension & Steering 7 Jul 11th, 03 6:15 PM
