What causes backfire through the exhause? - Chevelle Tech
Auto Insurance
2004 General Tech Forum from 2004
No new topics accepted - replies welcome
Old Sep 25th, 04, 5:19 PM
61dragon 61dragon is offline
Post
Hi Crew,
I am having a problem that is not really bad but it is just an anoyance.
My big block slightly back fires through the exhaust pipes when the engine is cold but goes away when the engine warms up. Awhile back, I did a cam, lifter and valve spring change but it ran ok at the time.
Has anyone experience this before?
Kent,
Quick reply to this message
Old Sep 25th, 04, 6:13 PM
RedSS454 RedSS454 is offline
Chris
Post
If I am not mistaken, the engine is firing when the exhaust valve is slightly open. I don't know for sure, but that sounds like it. Maybe check your timing. Too retartded? Maybe someone will chime in with a more direct answer.
Chris
'71 SS454 - Canadian Built
468" BBC, M-21, 3.55 12-bolt posi
"Real Race Cars Have a Clutch..."
Big Red Roastin' Em (Video)
The Body
The Soul
Other Project - 66 Cobra - 475"BBC
Old Sep 25th, 04, 10:49 PM
Resq302 Resq302 is offline
Send a message via AIM to Resq302
Post
Maybe it is a leak at the exhaust manifold? I have heard that they can sometimes cause a backfire in the exhaust. Also like RedSS454 said, might be timing.
Brian
Morris County, NJ
El Camino----The ORIGINAL Sport Utility Vehicle !
-1970 El Camino SS 396 (true SS, highly optioned car) AACA Senior Gold Winner (Hershey 2005) , 2006 Concours d'Elegance Star Award winner
-1969 Dodge Charger HP 383 ci. 4 spd AACA Senior National Winner (Herhey 2007)
Old Sep 26th, 04, 4:56 AM
ChevelleCLM ChevelleCLM is offline
Curtis
Send a message via ICQ to ChevelleCLM Send a message via AIM to ChevelleCLM Send a message via MSN to ChevelleCLM Send a message via Yahoo to ChevelleCLM
Post
Lean Mixture
Incorrect Valve timing
Incorrect Ignition timing
Alot of things really
69 Malibu Undergoing Ramjet Bigblock Project
87 Dodge Raider 4.3 700r4 NP231chd D44 SAS
95 Dodge Ram Freebie 318 turd
Old Sep 26th, 04, 9:48 AM
Unclepennybags Unclepennybags is offline
Mike
Post
Usually, when you backfire through the exhaust it's an A/F problem or a secondary ignition problem.
If it backfires through the intake it is a timing issue, either ignition timing or valve timing.
Mike
  #6
Old Sep 26th, 04, 3:30 PM
WestyJ69chevelle WestyJ69chevelle is offline
Post
check to make sure the exhaust manifolds, or headers if you got em' aren't leaking. I was having the same prob, I replaced the header gaskets on both sides, prob. solved
read your plugs too.. could be a bit rich..
"gun control means hitting your target."
  #7
Old Sep 27th, 04, 11:01 AM
Wilbur Wilbur is offline
Post
If it's backfiring thru the carb, Is the ignition too advanced? My engine will do it every so often, usually under load or just before the trans downshifts. Single pop thru the throttle body, then it's fine. I have computer controlled ignition, so I will have to alter the timing map if it's wrong.
69 Malibu, supercharged fuel injected 454 big block, 700R4 trans, 3.55 posi 12 bolt rear
There's no replacement for displacement
  #8
Old Sep 27th, 04, 2:59 PM
Chris R Chris R is offline
Post
I am having the same problem. And it is only out of the left side exhaust pipe. Perhaps that side is loose.
My 396 timing was at about 18 degreese btdc when I checked it. That seems about right to me.
Chris.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chevelle Tech > Team Chevelle > Archives > 2004      Current Topic: What causes backfire through the exhause?
Human Verification
You may not post new threads
You may not post replies
