| Chevelle Tech Current Topic: disc brakes | ||
| Brake Conversions Tech info on converting from drum to disc |
Will a disc brake set-up from a 1972 chevelle fit into a 1965 chevelle.
#2
Yes. You will need the proportioning valve, booster and master cylinder also. If you pull the set-up yourself, take the little brackets that hold the end of the flex hose to the frame.
------------------ Rick (Abilene Texas) 72 El Camino TPI 350/700r4 Aces #00140 TEAM CHEVELLE #00038 |
Rick, Do I use the control arms from the 72 or 65? Gary
you keep your control arms, just change the spindles.
[This message has been edited by Bob Tiley (edited 10-22-99).] |
Let me get this 100% right take a 72 chevelle spindle w/brake set up , booster and master cylinder add proporting valve and it will properly work ?? or must you worry about clearance of header because of adding shims to get caster & camber. Sorry if I sound stupid
#6
Claw, the only reason to add shims is if the spindle is taller. Which I do not think it is.
------------------ DG Springfield, Ohio 70 Chevelle Malibu www.wright.edu/~adams.6/chevy.htm TEAM Chevelle Member #0086 Genx member (Founder 4 Ohio) |
#7
No extra shims are necessary, The spindles are exactly the same height.
#8
Are the ball joints and tie rods the same too. Boy am I stupid or what..
#9
The ball joints are the same from 64-72 and the tie rod ends are the same from 64-70.
------------------ Leo Paugh Maryland Chevelle Club #017 |
#10
claw
You'd be stupid if you went ahead with no idea of what works. But asking proves that you are not. You may be ignorant about certain things but once you've done the swap you will no longer be ignorant of the facts. Then you can help someone else. Thats why we are all here. BTW-welcome. ------------------ Rick (Abilene Texas) 72 El Camino TPI 350/700r4 Aces #00140 TEAM CHEVELLE #00038 |
| Display Modes | |
