| Chevelle Tech Current Topic: 67 power booster/master cyl swap | ||
| Brake Conversions Tech info on converting from drum to disc |
i have a 67 chevelle with power drum brakes i want to convert to frt. discs. do i have to change the power booster and master cyl.i know i have to add a metering valve,and what about the disteribution block can i use my original one
#2
Colin
Yes you must change the master cylinder. Disc brakes use a larger volume of fluid to work. A disc specific master cylinder moves more fluid than a drum M/C. ------------------ Rick (Abilene Texas) 72 El Camino TPI 350/700r4 Aces #00140 TEAM CHEVELLE #00038 |
yes on the need for a proportioning valve and the distribution block can not be used, unless you go with the early style proportioning valve.
| Display Modes | |
