Brake Conversions Tech info on converting from drum to disc
Old Oct 4th, 99, 12:55 PM
James Black James Black is offline
Send a message via ICQ to James Black
Default
Has anyone converted a 68-72 Chevelle to the Global West in (LA)
special upper A-arm? A tall spindal is required. This spindal can be off a 70-81 F body among many others. Your imput is greatly appreciated. This set-up is for better handeling with negative roll in the front end. The Sunkman.
  #2
Old Oct 4th, 99, 7:37 PM
Fred Ont canada Fred Ont canada is offline
Default
James Im using Global's uppers with spindles from a 75 full size wagon 12" discs.It made a handler out of my 72 love the way it corners.Also using a Z28 fast ratio steering box.Straight lines or OK for the strip not too many on the road.Remember you cannot use 12" brakes with 14" wheels or drum brake wheels with discs...FRED
Old Oct 5th, 99, 10:14 AM
Havoc Havoc is offline
ian
Default
Whoa! What's difference between disc brake wheels and drum brake wheels?
Ian McDermott
1970 Chevelle SS 396
Gold Member #101
E-mail: havoc@chevelles.com
Web page: chevelle.dhs.org
ICQ UIN: 3923441
Old Oct 5th, 99, 5:43 PM
Wes V Wes V is offline
Gold Member
Default
Prior to disk brakes becoming popular, the shape of the back side of a factory steel rim was different.
In around 65 the car manufactures changed the shape in order to clear the disk brake caliper.
That's what people are talking about when they refer to "disk brake" rims or not.
Wes. Vann
Technical Reference & Wagons sections
Gold Member #5
Old Oct 5th, 99, 5:48 PM
ian
Default
so basically, any wheel made after 1965 will be fine on a car with disk brakes?
Ian McDermott
Gold Member #101
ICQ UIN: 3923441
  #6
Old Oct 6th, 99, 4:16 AM
Len Len is offline
Default
Havoc,
Stock steel wheels on a '66 fullsize (Biscayne) will NOT bolt onto a disc brake car.
Disc brakes first became available on '64(?) or so Corvettes, then in '67 on the other models.
It probably depends on the original application of a given wheel.
As far as I know ALL "Rally" wheels will work with disc brakes ('67-72 STOCK disc brakes), even the 14x6 Rally wheels.
However, these 14" Rallys will NOT clear a 12" disc brake setup such as Fred's.
I might be a little fuzzy on the 1st year for the Corvette discs.
Thanks.
[This message has been edited by Len (edited 10-06-99).]
  #7
Old Oct 6th, 99, 3:11 PM
Kevin Kevin is offline
Default
Vette discs first showed up in 1965.
  #8
Old Oct 7th, 99, 9:41 AM
66PetRat 66PetRat is offline
Scott
Default
I have installed the Global Kit but I'm still in the middle of the restoration and havn't done the alignment yet. The instructions tell you to use spacers on each end of the pivots and that the larger spacer goes to the front. I have heard that this is the wrong orientation for the spacers and that infact the larger spacer should be in the back to get the proper alignment.
Whats the scoop ? If this is the case I will be out a set of bushings and a nasty call to Global.
You may not post new threads
You may not post replies
