| Chevelle Tech Current Topic: 67-68 brake facts? | ||
| Brake Conversions Tech info on converting from drum to disc |
I was havin a disagreement with a friend of mine and he says that single piston calipers were available on 67-68 chevelles and I thought 4 piston calipers were available, some info would be nice if anyone knows what came factory besides drums those 2 years
Thanks Fatnova www.joel.net/fatnova |
#2
You're right, singles came out on the 69 models, at least for Chevelles. Not sure about the others.
All GM disc brakes before '69 were 4-piston, fixed-caliper design. The single-piston floating caliper design was used on all '69 and later models except for Corvettes and the JL8 '69 Camaros (and '68 service option Z28s) that had 4-wheel disc brakes.
I am currently doing a swap on my 67 SS, and I got ahold of the spindles, Proportioning valve, and silgle piston calipers along with rotors. I believe came off of a 69 Buick. I know the spindles will fit, can I still use the single piston caliper?
Yes as long as you put on the 69 style master cylinder.
#6
67,68 and 69 masters are the same. They are all the round design with the prop valve under the master. If your going to put single piston brakes on a 67 then you must use 69 type rotors, dust shields, caliper brackets, hoses and pads.
#7
I just converted a 68 ss to 4-piston caliper brake's.i'm having a leaking problem around the pistons on left and right side's of the front.i was told this is why gm went away from this design is this true?
#8
Bill Rose http://www.ssbrakes.com/
"River Road Rat Pack" A.C.E.S.- 4039 68 Restoration complete (AACA Grand National Winner ) Chevelle Chassis Body installation Engine pic 69 L-78 ElCamino resto complete The 71 SS-454 |
| Display Modes | |
