Brake Conversions Tech info on converting from drum to disc
Old Jun 16th, 99, 2:55 PM
Steve Schmidt Steve Schmidt is offline
Default
Will a 72 nova suspension swap over to a 68 chevelle? Both cars have V 8 motors.
  #2
Old Jun 16th, 99, 9:38 PM
Cam Cam is offline
Gold Member
Cameron Milne
Default
The Nova & Chevelle were 2 completely different car lines. The Chevelle used a full perimeter-type frame with controlled flex in the torque box(?) engineered in. The Nova used a unitized body with bolt-on subframes front & rear that mounted the suspension & cradled the engine. The Nova also uses leaf springs out back vs. the Chevelle's 4-wheel coils. Despite the fact that both car lines use short/long A-arm suspension with coils I really doubt very much that anything can be shared. For all the trouble, you might just as well go with those trick tubular A-arms & F-car spindles & brakes, and maybe some trick H-O Racing rear control arms (are they still in business?) and some serious wheels & tires, quick-ratio power steering & fat anti-sway bars.
Old Jun 17th, 99, 6:55 AM
Bob Tiley Bob Tiley is offline
Moderator
Bob
Default
Suspension - No
Front Spindles and disc brakes - YES
You would need to use your existing steering arms that bolt to the spindle that connects to the tie rod.
You may not post new threads
You may not post replies
