starter - Chevelle Tech
Auto Insurance
Top Tech Reference Tech Articles
Old Feb 17th, 00, 4:42 AM
buzz buzz is offline
Default
ive already done a search.i have a 70 chevelle with the small flexplate,a 74 350.the block has diagonial starter holes,every starter i try wont mesh with the flexplate.any ideas how i can get the right starter without changing the flexplate or drilling a new hole?
Old Feb 17th, 00, 8:36 AM
drptop70ss drptop70ss is offline
Hoarder Deluxe
Default
If you have the small flexplate ( believe its 12" vs 14" for the large) you need a starter nose with inline bolt holes, not the diagonal. If you block is only drilled for the diagonal bolts, you will need to switch to the larger flexplate and use the starter you have, with the diagonal bolts. I think the block should be drilled for the inline bolts also, if that is the case get a starter for a 307, all 307s I have had came with the smaller flexplate. Just verify the nose has the bolt holes inline, not diagonal..
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
55 chevy prostreet
69/71 camaros
Old Feb 17th, 00, 10:49 AM
Default
the orignal motor was a 307.i have that stsrter too.my 350 doesent have the bolt holes straight across.it looks like i have to change flexpates.
Old Feb 17th, 00, 1:08 PM
David Nafarrete David Nafarrete is offline
Default
That would be the easiest way. I had the same problem with my car. Didn't realize it until the car was back together.
If I were you I would just change the flexplate.
What I did was too much of a headache. I drilled the 3rd hole.
Old Feb 17th, 00, 4:04 PM
Steve S Steve S is offline
Default
You may already know this but, to change the flex plate without removing the tranny try this trick: As you remove the tranny to engine mounting bolts replace the top two and the bottom two with extra long bolts. Remove the rear tranny mount bolts and drive shaft. Now you can slide the tranny back far enough to remove the torque converter and flex plate.
  #6
Old Feb 17th, 00, 4:19 PM
Wally Wally is offline
Moderator/Gold 67
Default
Try this trick, bolt the starter on you want to use with the solenoid off the starter. You will only be able to get the one bolt in, make sure it is the right bolt. Square the starter to the flex plate, push the gear out and check for engagement. Next using a tranfer punch, go down through the long bolt hole of the starter and mark the block. All the blocks have boss on the under side, but they are not all drilled. Drill and tap the block for 3/8 16 threads, counter bore the top of the hole larger just like GM did. Done. Bolt the starter on and the small flex plate will work. Just did one for this 60 vette I'm working on. I'm using the late model LT-1 starter, it only fits the small flywheel.
Wally
Gold #67
67 Malibu "Small Block" second owner
90 SS454
71 Malibu "Small Block"
93 torch red vette(crashed)Bad day at Blackrock! 6 grand in damage!
[This message has been edited by Wally (edited 02-17-2000).]
[This message has been edited by Wally (edited 02-21-2000).]
  #7
Old Feb 18th, 00, 4:32 PM
DZAUTO DZAUTO is offline
Team Member
Tom
Default
BUZZ,
I have to go with Wally on this one. I would do almost anything to keep from pulling the tranny. Even though I only have 4sp cars, the procedure for drilling the second hole would be the same with a bell housing bolted to the block.
I, personally have always been fortunate enough to build blocks with 3 starter holes, so I have never done this procedure myself. But I just can't imagine that it could be difficult at all.
Heck, I might just have Wally run over and do it for me!
Tom Parsons
  #8
Old Feb 18th, 00, 5:55 PM
Moderator/Gold 67
Default
This is a self defence move, changing the flex plate after all the goodies are bolted in is like slamming your fingers in a car door.
And one other thing, don't let anybody tell you there is a starter that will solve the problem, been there. The small flywheel had the straight bolt pattern, not the stagger.
If you use the LT-1 starter, you need to grind the mounting pad so it will fit flat on the block, the regular GM starter works without doing this. Use the brace, brace it, make sure it has the rear brace, did I say brace it!
Wally
Gold #67
90 SS454
  #9
Old Feb 19th, 00, 12:31 AM
Default
thanks for your help guys.we just got a foot of snow.after im done digging out ill try drilling&tapping that hole.this happened to me about 20 years ago,i should have rembered,boy my fingers hurt.
  #10
Old Feb 21st, 00, 7:05 AM
Gene Chas Gene Chas is offline
Default
Buzz, you might want to search down David's post on drilling/tapping. It was a nightmare for him )I think) and is not such an easy chore with the block in the car. look at his post and you;ll see what I mean. Wally and DZ are consummate pros with really good tools. Just a warning, could be a real bitch.
Chaas
Gold #62/ACES
67 SS396/L88
You may not post new threads
You may not post replies
