Remove El Camino Bed Moulding/Trim - Chevelle Tech
Auto Insurance
Restoration Corner Where originality comes first.
Old Feb 8th, 04, 4:53 AM
Frank ballew Frank ballew is offline
Send a message via AIM to Frank ballew
Post
How is the best way to remove El Cmaino Bed Moundings/Trim without messing up.
Is there a tool that is used to do this.
Old Feb 8th, 04, 10:40 AM
RedElky RedElky is offline
Post
The rear corner pieces will come off after you remove the nut/nuts that are inside the rear qtr panel. pull the tail light housing for access. the thick pieces around the rear window have studs that also have nuts on them, but the headliner needs to be out for access to the nuts. The long stainless pieces on both sides of the bed have these "C" shaped clips that hold the trim on. Hope that helps.
Brian
ACES #923
Old Feb 9th, 04, 11:06 AM
TimC TimC is offline
Post
After you have the rear corner molding off you can just slide the long trim off by pulling it toward the rear of the car. Easier than trying to pry it off.
Old Feb 10th, 04, 2:06 PM
Post
Thanks guys.. This really helps!!!!
Chevelle Tech > Specialty > Restoration Corner      Current Topic: Remove El Camino Bed Moulding/Trim
Human Verification
