lock-up converter in a TH 400 - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Apr 10th, 03, 3:54 AM
jarsmith2 jarsmith2 is offline
Post
Does anyone have any experience with a lock-up converter in a TH 400? If so, what is the process to adding this to a trans. not currently set up for lock-up? Also, where can you find the lock-up converters for the TH 400 and how is the lock-up switch supposed to be set up? Thanks for any help.
John
Old Apr 10th, 03, 8:25 AM
Jay72 Jay72 is offline
Post
I don't think it can be done, even the overdrive 4L80E (which might be considered the later model version of a th400) doesn't have lock up.
There are switch pitch th400's that use a converter with two stall speeds and a switch in the trans to change between the two.
Maybe one of the transmission guys here can provide some more information.
1975 Nova w/1966 427/manual th400, 11.8 @ 115mph.
Old Apr 10th, 03, 8:33 AM
Oldani Motorsports Oldani Motorsports is offline
Post
John, I have not seen this done, as Jay indicated. The switch-pitch deal was used by Buick-Olds-Caddy(?) a long time ago. It had a setup that changed the stator fin angle. It was not a setup capable of withstanding much power though, it would blow the fins out of the stator if you made any power at all. I have seen many Powerglide race trannies that have been made into lockups, especially for ultra-high HP heavier car applications. But, you are looking at over $7K for a complete setup! Using a lockup in a TH400 sounds like you are maybe after some cruising economy, and not so much performance? I would look to one of the factory lockup trannies, there are quite a few HD parts now made for them. I sell TCI and JW, you can see the TCI stuff at www.tciauto.com, they have a decent website. JW has a site, but not much is on there.
Old May 17th, 03, 5:51 AM
Bob Cunningham Bob Cunningham is offline
Send a message via AIM to Bob Cunningham
Post
Actually there is a lockup conversion that was developed about 2 years ago. It is made by a company in New York, I think, I could look it up for you if you'd like. It was developed for racing, and will handle a lot of HP (800 - 900). The only downside is that it runs in the neighborhood of about $2,700 for the parts to convert it (including the convertor), then you essentially have to rebuild the tranny to install everything (another $400 or so, depending on your tranny shop) (unless you can do your own tranny rebuilds). It was intended to lock up at the end of the 1/4 mile so you can get improved efficiency and better MPH.
The switch-pitch is a much better way to go in my opinion. You will still have to remove the tranny and essentially do a whole rebuild (the front pump has to be replaced and you have to putz with some other internals), but is much cheaper and very strong- you can buy a conversion kit from Kenne-Bell (under $200 not including convertor), and a convertor for about $450 (www.trisheld.com. So if you add a bench rebuild from your local shop, you are in it for about $1,000. It is a wicked setup- in my daily driver, I get fabulous gas mileage and still occasionally can put about 750HP into it (although the convertor manufacturer recommends a limit of about 600HP). My convertor gives about 1800 low stall and 3000 high stall- works great for both highway cruising and for racing.
I gotta tell you, I love my switch pitch! I don't know why they aren't more popular. I can tell you, I'll never get rid of mine!
If you want more info on where to get the convertor, shoot me an email at bobcATgnttype.org.
-Bob Cunningham
Old May 17th, 03, 9:29 PM
Bomber '67 Bomber '67 is offline
Post
Not New York, but Tennesse: http://www.converter.com/vigilante.htm
I'm not sure where these come from, but http://www.converter.cc/C-5conversion.htm also offers lock up TH400 converters
FLP Trans has them in the works as well.
Old school be damned - you will be seeing more and more high hp cars going this route.
Thomas
El Caminos a pair: '67 Bomber, '65 496
Avanti, Corvette and more
  #6
Old May 17th, 03, 9:52 PM
70_chevelle 70_chevelle is offline
Post
I was under the understanding that Yank has what he called a posi lockup converter, the clutched locked by the torque, the more torque the harder it held. Call him to get the details.
Lee
230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
PowerGlide, 5000 stall converter. 8.70@154 MPH
My Projects Homepage: http://www.horsepowerracing.com
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: lock-up converter in a TH 400
Human Verification
