New clutch disc with old pressure plate? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Jan 13th, 04, 2:53 PM
New68SS New68SS is offline
Post
This is probably a really ignorant question but, here goes.
I'm about ready to reinstall the rebuilt 350 back in Amyes Z28.
I am absolutly broke at the moment and cannot afford a new clutch P/P assm'by but I hate to put the old unit back in with 107k miles on it.
Is there any benifit to putting a new disc in with the old P/P or should I just put the old unit back in until I can afford to replace it?
It was working fine before the engine rebuild.
The flywheel has been resurfaced.
Dwayne
Old Jan 13th, 04, 4:06 PM
1966_L78 1966_L78 is offline
Tony
Post
I am no expert, but I would think you could reuse the pressure plate with a new disc, provided you take a good look at the PP surface for any anomolies (crackes, shiny spots, grooves, etc). If it looks pretty good, you could dress up the surface lightly by hand with some emory clothe, and be sure to clean it thoroughly... Also check to see if any otthe springs are broken, etc...
As for the disc, if you need to reuse the old one, also inspect it carefully (hub splines and springs, etc). Make sure the rivets are well down within the lining. If the rivets are close to the surface, I'd definitely replace it...
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
Old Jan 14th, 04, 3:56 PM
Post
Thanx Tony,
I think I will just hold off on putting the engine back in for a couple of weeks until I can spring for the new clutch kit.
I hope the moly lube will hang onto the cam lobes that long.
dwayne
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: New clutch disc with old pressure plate?
Location
*REQUIRED*
Insurance
First Name
Human Verification
