Causes and symptoms of a broken valve spring - Chevelle Tech
Auto Insurance
1999 -- Tech Files - reference area
1000's of previous topics
Old Jan 25th, 00, 5:35 PM
David Flory David Flory is offline
Default
My 71 ss454 is making a noise that a friend says sounds like a broken valve spring. What are the causes and signs and smyptoms?
Quick reply to this message
Old Jan 25th, 00, 7:22 PM
Philip Philip is online now
Super Mod
Default
One of the symptoms is a loud tapping from the rocker arm. You will have a miss usually on 2 cylinders, one on each bank that share an intake runner. The easiest thing to do is take off the valve covers and inspect the springs. If you can rotate one with your hand it is bad.
Philip Valentine
Gold Member #42
"Perseverance is not a long race; it is many short races one after another."
philip@chevelles.com
Old Jan 26th, 00, 9:32 AM
RicksRag RicksRag is offline
Richard Morder
Default
David,
Pull the valve cover, look for anything obvious (broken pieces), pull the coil wire or unplug the HEI depending on which type of ignition you're running, have a friend bump the motor over, on each cyl, make sure they all are opening about the same (a wiped lobe won't open as much or at all), after the intake valve closes, check the rocker arms for loose (loose nut/broken rocker/bent push rod), see if the valve spring can be rotated (it shouldn't), try to rotate the push rods (they should spin true), this should put you on track.
Chevelle Tech > Team Chevelle > Archives > 1999 --      Current Topic: Causes and symptoms of a broken valve spring
Human Verification
You may not post new threads
You may not post replies
