What are the symptoms of a bad fan clutch? - Chevelle Tech
Auto Insurance
Heating & Cooling Heating, cooling and air conditioning
Old May 18th, 02, 1:07 PM
chevyjim chevyjim is offline
Jimbo
Default
How can you tell if a fan clutch is bad? I found one with a 772 fan that appears to have leaked a little fluid but still has resistance if you turn it. Also are these cluches supposed to lockup completely when hot?
Old May 18th, 02, 7:17 PM
chev64 chev64 is offline
Default
I would stay away from a leaky clutch, one of the symptoms is that the engine sounds like an airplane. The fans usually lock up at about 160 degrees.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
progress has little to do with speed, but lots to do with direction.
Old May 18th, 02, 11:20 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
Default
No, they do not lock up entirely when hot. A hand turn while hot or cold won't tell you much really. If it has leaked oil consider it shot. Even a little oil loss makes them work poorly since they don't have much oil in the first place.
NCOA member #220 ACES member #1670
Team Chevelle #998 YesterYears Chevys #52949
American Muscle Car Association #142
Rich's 1965 Malibu SS Restoration Project Progress Page
Old May 19th, 02, 1:01 AM
Ed Norris Ed Norris is offline
Default
I have heard the test is when you shut the engine off. If the engine is hot, the fan should stop soon after you turn it off, not spin freely.
sound right?
Old May 19th, 02, 11:28 PM
Schurkey Schurkey is offline
Gold Founding Member
Default
They can fail in many ways.
1. Any fluid leakage means it's toast.
2. They can seize solid. That's the "sounds like an airplane" way.
3. They can fail to engage. Engine overheats.
4. With the clutch firmly bolted to the waterpump, any fore/aft play in the fan blades means the bearings are shot. This often happens before the bearings lock up, as in #2 above. If the thing craps out the bearings badly enough, the fan goes through the radiator. Ouch.
  #6
Old May 20th, 02, 8:39 AM
Jimbo
Default
Thanks guys, I think I will get a new one and be safe.
LS 5 1970 Hardtop M21 3:42 / L34 1970 Convertible TH400 3:42
Chevelle Tech > Mechanical > Heating & Cooling      Current Topic: What are the symptoms of a bad fan clutch?
Location
*REQUIRED*
Insurance
First Name
Human Verification
