Restoring Seat Belts - Chevelle Tech
Auto Insurance
2001 General Tech questions from 2001
Replies ONLY, no new topics.
Old Feb 10th, 01, 9:50 PM
19Chevelle70 19Chevelle70 is offline
Default
Anyone know of a way to turn my faded black seat belts back into black seat belts?
Quick reply to this message
Old Feb 11th, 01, 1:20 AM
Rainer Rainer is offline
Gold Member
Default
Marhyde makes a spray dye for nylon carpets, etc. that works well on seat belt webbing too. Note that this is different than dye for vinyl upholstery. Good luck!
Rainer Seitz
Vancouver, WA
Team Chevelle Gold #50
ACES #3784
'68 SS396
'70 LS3 400 Malibu
'70 Malibu convertible 350/300hp
and the latest - '70 Malibu 454!
See them all at the all-new Rainer's Hot Rod Shop!
rseitz@chevelles.com
Old Feb 11th, 01, 1:24 AM
Default
Do you know where I can get ahold of some of this?
Old Feb 11th, 01, 5:19 AM
boatanchor boatanchor is offline
Default
I know where you can get it in North Jersey, (which of course is no help to you...) Why don't you try www.bondomarhyde.com/ I bet they can put you in touch with a local distributor- (I've used their Hi-temp paints, very durable)
'66 Malibu, 2 dr. hardtop
L6-230ci
Old Feb 11th, 01, 9:38 AM
Gold Member
Default
I have picked this up at the chain auto parts stores. Its called Marhyde Fabric Color, and the item # is 2150 in black. Its for carpet, velour, & upholstery (not vinyl or plastic), essentially items made from nylon or similar material.
Rainer Seitz
Vancouver, WA
ACES #3784
'68 SS396
'70 LS3 400 Malibu
  #6
Old Feb 11th, 01, 9:47 AM
JWagner JWagner is offline
Gold Member
Default
I have used the Rit fabric dye successfully for black belts. It is available in most grocery and hardware stores. The dry powder stuff works pretty well; I have not tried the liquid type. Cost is about $1.50 per package.
  #7
Old Feb 11th, 01, 9:56 AM
gibbons gibbons is offline
Default
The previous owner of my car used that spray on dye stuff on my belts. After a few years, it had faded unevenly and made the belts go stiff. I had to buy another set of used ones. The new one were faded, too, but at least they weren't stiff.
I wanted to dye them, but do it right. I bought some of that Rit stuff at a fabric store, but the instructions weren't very clear, especially for nylon. I called their customer support 800 number, and talked to their engineer/chemist and asked how to dye seat belts. He laughed, and said funny I should ask, he used to work for DuPont in the seat belt group, and knew exactly how to do it.
I am sorry don't remember the details, but there is a process he told me and I used. It was something like mix the dye in water (precise amounts), then bring it up to some exact temperature (like 180 degrees). Then, chuck the seatbelts in, and cook them for so many minutes. At the end of that time, remove the pot from the heat, and stir in an amount of vinegar. Let them sit for so long, then take them out of the solution and put them in cold water.
It worked fantastic, they really do look like new. Again, sorry I don't recall the details, call the dye company and see if you are as lucky as I was to get routed to the right guy.
  #8
Old Feb 11th, 01, 9:46 PM
ilbl8 ilbl8 is offline
Send a message via ICQ to ilbl8
Default
please be very carefull about doing this stuff. nylon weeken's with age from UV exposer. a seat belt could save your life! i would replace them! you can't be too carefull! keep the original one's if you want to show the car or something...but use new belt's in it for driveing and such.
i was a M.P. in the army, seat belt's save live's. i investigated only one accident where the seat belt helped kill the driver, it was an off road misshap with a jeep that went off a clif, the drive could not jump free cause of the seatbelt. it would not relese, acording to the passenger that lived.
Chevelle Tech > Team Chevelle > Archives > 2001      Current Topic: Restoring Seat Belts
Human Verification
You may not post new threads
You may not post replies
