1965 Chevelle SS frame off, pro touring. CA - Chevelle Tech
Auto Insurance
Welcome Forum Stop in and introduce yourself.
Old Jan 2nd, 14, 9:12 PM
classiccaraudio classiccaraudio is offline
Eric
Default 1965 Chevelle SS frame off, pro touring. CA
Just finished my 1965 SS, 4 speed.
I have over 200 pictures. Did not know witch ones to use. If any body wants other pictures just let me know and I can post some.
Where to start?
The Tree in the last picture of the car is over 300 feet away. Just showing how deep and clear the paint is.
This car is 100% done and hands down one of the nicest 65 ss out there.
This 1965 SS 4 speed Chevelle.
Body pulled off Chassis.
All body and paint done to show. Painted inside out. All gaps are better then new.
Frame is completely restored and powder coated Satin Black.
New body poly. bushing to body & new bolts.
Motor & trans:
G.M crate 350 330 hp. Turn key motor from G.M
New Poly. motor mounts.
Rebuilt Muncie 4 speed with factory shifter and linkage with Chrome stick and ball. Factory 4 speed car with center console.
March serpt. belt set up with bracket and pulleys.
New Mini starter.
New Powder coated 1 wire alt.
Coated headers.
MSD complete set up with box and billet dist.
New Billet fly wheel.
New MCLeod 11" clutch set.
New G.M 11 bell housing and cover.
New custom made drive shaft.
Powder coated brake and clutch pedal set up.
Brakes:
Baer Track 4, front and rear disk brakes with E-brake installed. Drilled and slotted rotors. Stainless lines.
Rear End:
Powder coated 12 bolt posi rear end with 3:73 gears. Custom Yukon axles.
Suspension:
Rear:
Hotchkis tubular "Total Control" rear suspension with adjustable control arm braces. QA1 adjustable shocks. All powder coated.
Front:
Global West Upper & Lower tubular front suspension with QA1 coil overs.
Fast ratio steering box. all powder coated as well.
Wheels & tires:
Brand new 16" torque thrust wheels with new tires.
Absolute show quality body work, panel fit, and Spies Hecker (most expensive paint you can buy) urethane base coat clear coat paint that has been polished to absolute perfection. Car is painted inside down and inside out. Come look. You will not find a wave or flaw in it.
Factory Front & rear seats are cleaned and recovered (stock) Rear springs were powder coated..
New head liner is also installed with new sun visors and under pad.
New American Auto wire complete car harness.
New 4 speed Z bar & linkage set up.
New Original center grill and emblem.
New Black carpet kit.
New lock set.
New outer door handles.
New tail light lenses.
New Black dash pad.
New gauge bezel and glove box emblem.
New glove box insert and working glove box light.
Complete new interior kit. Including: All Black
Head liner.
Complete sun visors.
Complete front & rear door panels.
Complete front & rear arm rests with pads.
Complete front & rear seat covers. I had springs out for powder coat and have the new cover installed.
Complete new rubber & seal kit.
Factory gauges all rebuilt.
Factory tach (new)
New gauge lens.
New head light switch and nut.
New ignition switch and bezel.
New wiper switch and nut.
New E- brake cable from under dash to rear brakes installed with all new cables and clips.
New front & rear bumper and powder coated brackets. ( also have stock bumpers)
New complete front marker light assemblies.
New complete back up light assemblies.
All new trunk stainless and letters and emblems.
New complete SS emblem kit with fender flags for the complete car.
New hood spear.
New wheel well stainless.
New Flaming river tilt column (powder coated black), also have the stock.
New EMS billet hood hinges.
New Chrome brake booster and new master cylinder.
Powder coated battery tray.
New front bumper & marker lights with powder coated brackets.
New battery.
New battery cables.
New coated headers.
New Billet hood latch.
New DSE 7 speed wiper motor.
New steering wheel and horn button.
New front windshield.
New dual flow-master 2.5" exhaust with cross over pipe.
New billet Lokar brake pedal.
New Custom Auto Sound (I-pod) stock looking radio.
New custom Auto Sound kick panels with KenWood speakers.
LED interior dome lights.
Powder coated Gas tank and new sender are installed with new fuel line.
Both powder coated inner fenders.
Also installed Powder coated heater box, inner and outer, new heater core, New fan motor.
100% done.
QA1 billet rear shocks.
New Marker light assemblies.
New Aluminum radiator.
Heater hoses and lower radiator hose done with custom shrink clamps.
Dynomat floor and head liner.
Billet thermostat housing.
Got black spark plug wires ran with custom brackets. Had to buy 2 sets of wires to get them to run the way I wanted them. They look great. Ran a nice hard gas line to carb from pump.
Installed a black flex fan and spacer.
Sand blasted and painted the wiper transmission and installed it.
Click image for larger version
ID:	135089   Click image for larger version
ID:	135097   Click image for larger version
Name:	65 SS update 023.jpg
ID:	135105   Click image for larger version
Name:	1965 chevelle ss 002.jpg
ID:	135121   Click image for larger version
Name:	1965 chevelle ss 015.jpg
Old Jan 2nd, 14, 10:55 PM
Chris R Chris R is offline
Default Re: 1965 Chevelle SS frame off, pro touring. CA
Looks fantastic.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Old Jan 3rd, 14, 10:22 AM
MikeMalibu MikeMalibu is offline
Team Member
Mike
Nice work. I used to live in Felton will attending Uncle Charlie's Summer Camp.
Old Jan 3rd, 14, 10:55 AM
shadowgray396 shadowgray396 is offline
Ray
Very nice job, looks great
70 SS Chevelle Van Nuys Cal Built
http://s777.photobucket.com/albums/y...70%20chevelle/
Chevelle and El Camino Club of Oregon
http://www.chevelles-oregon.com/home/
Old Jan 3rd, 14, 11:10 AM
Eric
Thank you.
I am having the car polished today, so should have better pictures to follow.
Name:	65 & 66 chevelle 037.jpg
ID:	135273   Click image for larger version
Name:	65 & 66 chevelle 054.jpg
  #6
Old Jan 3rd, 14, 4:31 PM
Freddy Mercado Freddy Mercado is offline
Gold Member
Freddy
Very nice car!!! Welcome to the site.
  #7
Old Jan 3rd, 14, 7:41 PM
oktunes oktunes is offline
Matt
What is the price?
  #8
Old Jan 6th, 14, 1:37 PM
BMR Sales BMR Sales is offline
Supporting Vendor
T.C.
Welcome to the Site, Eric! Car looks Very Nice!
T.C.
BMR SUSPENSION
TAMPA FL
813-986-9302 Phone
813-986-8055 Fax
TC@BMRSuspension.com
www.BMRSuspension.com
Like us on Facebook!
  #9
Old Jan 14th, 14, 10:35 AM
Eric
Thank you.
Just had the body shop foam pad and polish my 65 SS. I did not think the paint could get any deeper, but it did.
Since pictures added deluxe retractable front seat belts, matching rear set belts.
Ring Brothers billet hood stops.
Some current pictures.
Name:	65 chevelle ss 033.jpg
ID:	138825   Click image for larger version
Name:	65 chevelle ss 035.jpg
ID:	138833   Click image for larger version
Name:	65 chevelle ss 017.jpg
ID:	138841   Click image for larger version
Name:	65 chevelle ss 022.jpg
  #10
Old Jan 14th, 14, 2:28 PM
Sleez Sleez is offline
Lee
couple questions;
are you using an early narrower 12 bolt, or a later one?
what are the dimensions of the wheels and tires? (BS, etc.)
thanks
65 Chevelle 300 Deluxe 4dr Wagon
  #11
Old Jan 21st, 14, 8:00 PM
AldoNova67 AldoNova67 is offline
Team Member
Loving it.....looks like a top quality job.
  #12
Old Jan 25th, 14, 6:38 PM
Eric
Thank you.
It is a factory 65 chevelle 12 bolt. Just powder coated, Yukon axles, posi, Bear brakes.
Chevelle Tech > Welcome Forum      Current Topic: 1965 Chevelle SS frame off, pro touring. CA
Human Verification
