Manual trans guys I found a good source for a 2 step wobble switch - Chevelle Tech
Auto Insurance
Old Dec 1st, 13, 9:01 PM
ChevJerico ChevJerico is offline
Default Manual trans guys I found a good source for a 2 step wobble switch
After looking for a cheap or used jake brake switch, and not having much luck. I found the industry nomenclature for these things is "wobble switch". May not be the best option, but found this one on Ebay. Many to choose from!
Also Pacbrake has one that's available at your local truck parts store for around 35$
http://www.ebay.com/itm/231069132445...84.m1438.l2649
1970 Chevelle, 400, UD solid, 5.565 rod, standard bore, vortec heads, Jerico DR4, best ET 11.85, 113 MPH
1961 Buick Lesabre convertible, bone stock cruiser
Old Dec 2nd, 13, 9:17 PM
383ram 383ram is offline
Chad
Default Re: Manual trans guys I found a good source for a 2 step wobble switch
Huh, never thought of that to use---I assume your using the arm of the clutch pedal to activate it?. We have them at work (Cummins) on the shelf---well, last I knew anyhow. Wonder how expensive ours are.
Built Ram tough with Chevy stuff.
454/4-speed overdrive swap into '85 Dodge Ram.
Mopar guy building a Chevy.
454, PP heads, dual 500cfm carbs and 'Vette manifiolds...First time out..Tire spin for half track
454 semi budget build Part1 followed by PartII
http://www.chevelles.com/forums/showthread.php?t=326289
Old Dec 2nd, 13, 11:21 PM
novaderrik novaderrik is offline
Derrick
what is it for, and why won't a microswitch work?
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
Old Dec 3rd, 13, 8:36 AM
Calculated Risk Calculated Risk is offline
Rick
I use a micro switch. It's the size of 2 quarters and weighs maybe 2 ounces.
It's set to turn 2step on with the clutch pedal to the floor, I set the clutch airgap with the pedal on the floor. It worked good and never effected the shift. The same micro switch has been in the car since 1996.
I swapped to an auto a few years ago and now i use the clutch pedal as my line lock switch.
Chevelle Tech > General Tech Area > Performance      Current Topic: Manual trans guys I found a good source for a 2 step wobble switch
Human Verification
