Bbc - Chevelle Tech
Auto Insurance
Old Oct 17th, 13, 7:56 PM
firecap44 firecap44 is offline
paul
Default Bbc
I have a 66 396 that I have always had trouble with but wanted to keep in my car just due to saying numbers matching. I rebuild that thing bored big cam roller rockers and so on. So here my issue it's a as I told a late 65 early 66 motor and since I have all the new stuff on it I would like to use. The motor ran pretty good once installed but then I ran up a stump with sickness, jobs and just life I let it sit in my garage and thought I drained the water out of the rad, and block but that winter even in my gargle got could enough to push 2freeze plugs out. So to present time got fired back up but it seemed to turn slow so I got new starter still slow, so pulled dip stick and I have water. So here's my question would yaw just start all over with a complete setup such as a newer big block which my stuff I have now will not work or find a block and put my stuff in? Or another thought get my block tested before anything and see if it is cracked or not?
Old Oct 17th, 13, 8:25 PM
2BlueLS6's 2BlueLS6's is offline
Default Re: Bbc
Test it. You may even see noticeable damage inside the block with the naked eye if it's cracked. I've seen one that had a golf ball size hole in there up between the camshaft area and bottom of cyl's from freezing and bustin'.
Also, did you use a camshaft that was compatible with the early block? If it's '66 the rear journal on the camshaft has to be grooved.
Old Oct 17th, 13, 8:46 PM
bracketchev1221 bracketchev1221 is offline
Default Re: Bbc
Its up to you. 396 blocks are kind of cheap since everyone wants a 454 block now. So it may worth rebuilding what you have. Have yours checked and see what failed. But that being said, the cost of a rebuild for a 396 and 454 is the same.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
Old Oct 17th, 13, 9:03 PM
nashville beth nashville beth is offline
Team Member
Beth
Default Re: Bbc
If you want to have fun with the car, why build a 396 ? Every part from a 396 will fit a 454 except the pistons. The 454 will be up by 50 hp over a similarly built 396.
Take your time and you can find a good engine or block. Gas is $3.25 and big blocks can be found at a decent price if you are patient.
Here's one in Birmingham : http://bham.craigslist.org/pts/4135857456.html
68 Camaro conv, 454 T56 in progress
"There are two ways of arguing with a woman.......and neither one works !"
Old Oct 17th, 13, 9:39 PM
paul
Default Re: Bbc
Yes I had the cam taken and groved and I have about decided to test it
  #6
Old Oct 17th, 13, 9:42 PM
paul
Default Re: Bbc
O shot close to me and a deal I think
  #7
Old Oct 17th, 13, 9:44 PM
kettbo kettbo is offline
George
Default Re: Bbc
but since it is the numbers block, do have it evaluated. if it has minor flaws, even some cracks, some super machinists here may be able to save your block for you.
WOLFPLACE in N California is one such guy. He may know someone local to you that can fix. Again, all depends.
once fixed, store the born-with block (so you can preserve it for posterity and not feel bad about blowing or wearing out the next engine).
454 block, your crank and rods, new pistons for 427 and you have a 427
or do a 454
or buy a 496 built
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
Chevelle Tech > Mechanical > Engine      Current Topic: Bbc
Human Verification
