Installing an Idit or other Steering column - Chevelle Tech
Auto Insurance
Interiors Upholstery and soft trim
Old Nov 17th, 02, 10:38 PM
Maliblu65 Maliblu65 is offline
Default
Is it a major deal to install an Idit or other replacement steering column? Any big fabrications?
Burke
Old Nov 17th, 02, 11:19 PM
FULMNTE FULMNTE is offline
Default
As far as I remember, most aftermarket columns do not have ignition switches and locks in the column and you woul have to install a separate swicth/lock in or under the dash.... Keep this in mind when you look for a column...
71 Monte 454 HO 5-Speed "FULMNTE", 100 HP Nitrous
www.71Monte.com
Old Nov 18th, 02, 10:41 PM
MAXX2 MAXX2 is offline
Team Member
Default
Search under some of the forums for replacement columns. We used an '82 Camaro Tilt Column (Floorshift), with great success.
Team Members Forever #341
Richard, Judy, MAXX2
'69 Elke (Frame Off); GM HO 350/330-Mildly Ported Vortec Heads-Manley Severe Duty SS 2.02/1.60 Valves, Comp Cams Full Roller Package (Magnum)-Custom Grind CS 3315/3316 HR112-.510/.520 Lift, Edelbrock Air-Gap W/750 Performer Manual Choke-Performer 100 HP NOS, March Pulleys, 4L60 (Non Computer) W/Lokar Shifter, 12 Bolt Posi., Full Aluminum Bed With Full Tubs, Aluminum Firewall, Custom Aluminum Dash/Gauge Bezel.
Old Nov 19th, 02, 1:13 PM
1966_L78 1966_L78 is offline
Tony
Default
I have been checking for my 66, and if you are installing this in a 65 Malibu(based on your screen-name), then you don't have to worry about a different ignition switch... the stock ignition switch didn't come on the column until the 1969 models...
As far as I can see, its a bolt in, but you need to make sure the supplier knows what other parts are needed (might need adapters for steering box, wiring and steering wheel-might not come with a standard column)... One supplier I have seen is CPP (not sure of the actual name-something like Classic Performance Parts, or something...
"Once you go RAT, you never go back..."
TC #1366
Tony
The Chevelle
Dual Quad 396
Side View
Old Nov 19th, 02, 10:05 PM
Default
Thanks for the info! What I have is a 65 malibu going from a PG to Richmond 5 speed. The steering column needs 80.00 worth of trashed blinker assembly and still has the automatic column indicator, ect. So I am looking at alternatives.
Burke
Chevelle Tech > General Tech Area > Interiors      Current Topic: Installing an Idit or other Steering column
Location
*REQUIRED*
Insurance
First Name
Human Verification
