1965 Super Sport - Chevelle Tech
Auto Insurance
Pro Touring Todays performance with classic style
Old Aug 12th, 13, 11:59 PM
1965_ss 1965_ss is offline
Todd
Default 1965 Super Sport
So I picked up this 65 SS a few months back. It's an original SS with protecto-plate. It's got about 90,000 original miles. Previous owner rebuilt the original engine as you can see and I didn't get any of the original parts to the engine, long gone. The previous owner also put in a turbo 350 trans, powerglide long gone also. The original 10 bolt still is in place and up front the previous owner added disc brakes. It also came with an aluminum radiator with electric fan. The interior has been completely redone. The previous owner also added the rims and tires. How you see it is how I bought it. The only thing I've done so far is add a Wilwood master cylinder and rear seatbelts to match the front so I can take the kids out.
I'm thinking DSE components, BAER brakes, ABC Performance mini tub, El Caminio boxed frame, etc, etc.......
Progress will be very slow $$$, I just figured I would start a thread and update it once in awhile.
Click image for larger version
Name:	IMG_9419 - small.jpg
ID:	103681   Click image for larger version
Name:	IMG_9420 - small.jpg
ID:	103689   Click image for larger version
Name:	IMG_9422 - small.jpg
ID:	103697   Click image for larger version
Name:	IMG_9429 - small.jpg
Name:	Engine Rebuild - small.jpg
ID:	103713   Click image for larger version
Name:	IMG_0842 - small.jpg
_____________________
Todd
1965 Chevelle Super Sport
Old Aug 13th, 13, 12:36 AM
YankeeRodder YankeeRodder is offline
Dave
Location: Aloha Oregon, a rainy but very green Portland suburb
Default Re: 1965 Super Sport
Very nice!!
My 1970 Chevelle SS half-clone. Not a pretty face,
just a battle scarred old former street fighter looking for a few more rounds.
http://i133.photobucket.com/albums/q...0908121550.jpg
Old Aug 13th, 13, 7:23 AM
craigs66 craigs66 is offline
Craig
Todd,
Very nice car ! Can you provide the wheel and tire sizes?
Craig
Old Aug 13th, 13, 10:33 AM
malibuss427 malibuss427 is offline
Tony
Looks like a real nice car, enjoy.
Old Aug 13th, 13, 10:55 AM
65_LS1_T56 65_LS1_T56 is offline
Aaron
About time
Nice car Todd. I'd have some suggestions for you about the frame/chassis selection and modification based on my experience.
Let me know if you'd like a pm or put it here.
Looking forward to you're project transformation.
Aaron
65 Chevelle HT, Project G-Velle
  #6
Old Aug 13th, 13, 11:34 AM
Todd
Originally Posted by YankeeRodder View Post
Very nice!!
Thanks!
Originally Posted by craigs66 View Post
Todd,
Craig
17x8 5" backspacing 245/45-17, 18x9 6" backspacing with .25 spacer 265/50-18. This is the backspacing that was told to me by the previous owner, I have not measured it myself.
Thanks!
Originally Posted by 65_LS1_T56 View Post
About time
Sounds good! Now you know why I hang out in your build thread
Todd
  #7
Old Aug 13th, 13, 1:15 PM
Aaron
So on the El Camino frame you mentioned, why use that instead of boxing a HT frame? If you are considering the ABC minitubs, you'll be sectioning the rear frame rails anyway. Plus, the El Camino frame is longer behind the rear axle, so it would need to be shortened anyway. Just my thoughts.
I boxed and notched mine before Tony's kits were available. Now that the parts are available, it would be a huge time saver to use them. Could you do it cheaper? probably. But not when you figure in all the time to make templates, adjust, cut, trim, and weld them.
DSE makes some quality stuff no doubt, and it works. As you know, I have ABC front and rear stuff with Ridetech T/A's on mine. Couldn't be happier. But I have nothing but stock stuff to compare it to. One thing that is unique about his rear suspension is the use of OEM type cross-axis joints for full and smooth articulation. Plus the joints are fully sealed too, a plus for daily driven cars. I think the Ridetech suspension would be a great setup too. Too many choices All things to consider of course.
Ok, you started the build thread, now we can hound you for updates
Aaron
  #8
Old Aug 13th, 13, 3:54 PM
Todd
On the frame.........this car had been hit in the right front so the frame horn has been repaired, kind of. You can tell it was heated up and pulled on with a chain, leaving chain marks and metal that is bent up and down on the front horn rail. The only reason I'm thinking of an El Camino frame is because I have a friend that has a 67 frame that I could use. I know it would have to be shortened a little in the back, but the side rails are already boxed so that saves some time there....maybe? So I either use his frame or find another, either way I want to do the ABC kit. I want the Roadster Shop chassis real bad but I don't have $20K sitting around. I was thinking of building up the 67 frame on the side as time and money permit and then just swapping the body over to it when it's done. This keeps my car drivable. We shall see.
Todd
  #9
Old Aug 13th, 13, 6:20 PM
Aaron
I figured there was more to the story. That makes sense then. Just wanted to make sure you knew about the rear section being longer. Oh, of course you'll need a trans crossmember too, but if you boxed one or use the elky, that is still true.
And who doesn't want a RS chassis, bad ? They do such nice work.
Aaron
  #10
Old Aug 13th, 13, 6:56 PM
Todd
If I end up using that other frame I figured I would have to shorten it by 3.27 inches. I will have to see if he's got the El Camino crossmember
Todd
  #11
Old Aug 13th, 13, 9:34 PM
Blitz Blitz is offline
Keith
Always love it when I see another 65 in THIS section. More "steal" ideas from I guess. Bwaahahaha
Great factory shade too. Mine in SS trim.
I drive...a 65
  #12
Old Aug 13th, 13, 10:29 PM
rxn0001 rxn0001 is offline
Rob
Nice car! It looks good as it sits now but what fun is it to leave it alone? Have fun with your build!
Rob
1965 Malibu SS
http://www.chevelles.com/forums/showthread.php?t=453554
  #13
Old Aug 13th, 13, 11:14 PM
cgocifer cgocifer is offline
Dan
Sweet, another 65!
Dan
1965 Chevelle 300 2dr Post Sedan
Project: High School Sweetheart
http://i198.photobucket.com/albums/a...edCar65085.jpg
Project High School Sweetheart Thread: http://www.chevelles.com/forums/showthread.php?t=352238
  #14
Old Aug 14th, 13, 12:42 AM
Todd
Thanks guys! I've read all about your cars before Awesome cars!
Todd
  #15
Old Aug 14th, 13, 12:45 AM
Todd
It is a factory white with two tone blue interior. When the previous owner redid it he kept it original. You don't see that very often........I might change it in the future though, although that is WAY down the line....I want performance parts first
Todd
Chevelle Tech > Specialty > Pro Touring      Current Topic: 1965 Super Sport
Human Verification
