Engine Weights SBC-vs-BBC-vs-BBC - Chevelle Tech
Auto Insurance
Old May 4th, 13, 8:25 PM
JOHN WILSON JOHN WILSON is offline
Clueless TnTr
Send a message via AIM to JOHN WILSON
Default Engine Weights SBC-vs-BBC-vs-BBC
Here's how the weights compare between the 3 motors I weighed. Strictly for reference. The sbc is a Dart-IE block with raised runner Brodix 18 heads and aluminum pan. The 496 is a production 2-bolt block with 781 ovals and Milodon steel pan, and the 548 is a GM Gen-4 block with Dart-IE heads and Moroso steel pan. All were measured dry. The 496 had an empty oil filter and flexplate mounted, the other 2 did not.
496bbc:
440sbc:
548bbc:
Old May 4th, 13, 9:43 PM
-SS454- -SS454- is offline
Chris
Default Re: Engine Weights SBC-vs-BBC-vs-BBC
what do you think accounts for the additional weight of the 548?
Old May 4th, 13, 10:08 PM
BBC71Nova BBC71Nova is offline
John
So these are both iron headed big blocks?
Old May 4th, 13, 10:09 PM
Clueless TnTr
Heads & block would be my guess.
Old May 4th, 13, 10:17 PM
nashville beth nashville beth is offline
Team Member
Beth
I think he was asking about the difference between the 496 and 548.
So if aluminum heads save a minimum of 80 pounds on a BBC, that would put the BBC within 40 lbs of the SBC.
Not much difference.
68 Camaro conv, 454 T56 in progress
"There are two ways of arguing with a woman.......and neither one works !"
  #6
Old May 4th, 13, 10:19 PM
Clueless TnTr
Both bbc's are iron heads/block. Sbc is alum head/iron block.
  #7
dtrubey dtrubey is offline
Team Member
Dal
Thanks John. Interesting....
70 Chevelle - 3200#
Just a little NA 511...
5.83@118.42, (9.24/25 @ 144+)
______
CrazyDaveyRacing.com
  #8
Old May 4th, 13, 11:19 PM
John
So aluminum block and heads would knock those BBC setups down another 100-150lbs I guess? Gotta go figure out how much an LS3 weighs now...
  #9
Old May 4th, 13, 11:25 PM
Wolfplace Wolfplace is offline
Mike
John
Who's scale is that?
I like it a lot better than my platform one,, have to lift the stuff to set in on mine anyway,, might as well weigh it hanging there instead of dragging out the platform..
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
  #10
Old May 4th, 13, 11:26 PM
BACK FROM THE DEAD BACK FROM THE DEAD is offline
Andy
So then an aluminum-headed bigblock should likely weight less than an iron-headed smallblock by this method of thinking, right? If not at least very close to the same then...
New project:Red/Blk Stripes 70 SS-565" FAST+XFI, 819 HP/ 735 TQ on pump-gas. "Red Dead"!
Sold: My 71 SS 454 clone "Back from the Dead" http://i68.photobucket.com/albums/i2...lemay05005.jpg
  #11
Old May 5th, 13, 12:46 PM
Clueless TnTr
Regarding bbc vs sbc weights. I can't really say what a different combo would weigh. I just put these out there for folks to see. Some things to keep in mind are the 548's block is a 4bolt Bowtie block that is likely heavier than a production 2bolt block, the Dart-IE heads likely weigh more than the GM 781's. That's where the weight difference is between the 548 and 496 (most of it anyhow). On the 440sbc, the Dart-IE block is a heavy piece especially compared to a production Gen-1 block. The heads are raised runner units that will weigh more than a typical 23 alum head, along with the intake being heavier. I would speculate that a typical production block 406 with Al heads would weigh-in ~40-50lbs lighter than this 440.
Originally Posted by Wolfplace View Post
John
Mike, not sure who makes it. I picked it up on ebay for ~90 bucks IIRC. It's rated to 1000lbs and gives repeatable numbers. Pretty nifty for the money, IMO.
  #12
Old May 5th, 13, 1:52 PM
CPMotorworks CPMotorworks is offline
Pete
Just weighed a couple myself the other day, 660 lb scale from ebay for $60.
Bare Pontiac 400 block 177 lbs.
One piece seal 880 block
355 Iron head Vortec
RPM Intake Iron water pump with pulleys
153t flexplate
MSD ignition
5qts oil
Cart without casters
453.8 lbs
OEM 400 block w/splayed caps
18x Heads 1801 intake
Aluminum water pump
Balancer and 153t flexplate
No oil or Distributer
Cart with casters
454.2 lbs
CP Motorworks,Inc
www.cpmotorworks.com
Custom Performance Engines &
Cylinder Head Fixtures for Vertical Mills and Surfacing Machines
1971 Chevelle 406- Mine- ET to be determined
1970 Chevelle 496- 10.2:1, 781 ovals, 3.31, 275/60 DR 3800lbs, 10.92@124.7 on 91 octane - Hers
  #13
Old May 5th, 13, 11:56 PM
Team Member
Beth
Here's one that weighs up to 1100 lbs and is about $80 :
http://www.ebay.com/itm/Digital-Hang...item564e489984
I think I'll get one
  #14
Old May 6th, 13, 7:48 AM
Busted Knuckles Busted Knuckles is offline
nashville beth, if you make an offer that's accepted, ping me, I think I'd like to have one of those as well. I ship a good bit of stuff overseas, sure would help to be in the ballpark on weights. Past sales are for listing price, I guess nobody made a decent offer.
Gary Adrian
FCS Harmony Racing
'Cause if they catch you in the back seat trying to pick her locks,
They're gonna send you back to mother in a cardboard box...
You better run!
  #15
Old May 6th, 13, 8:32 AM
Andy's Auto Repair Andy's Auto Repair is offline
Andy
For $80, not even argueing over it. Got one coming.
2014 Chevrolet SS 6.2 auto/ 2014 ZL1 Camaro 6.2 6 speed SC/ 2011 DurtyMaxx/ 2009 Tahoe 6.0/ 1994 Wrangler 6.0 /1981 Malibu 505/ 1971 Monte 496/ 1970 Chevelle454 1970 Monte 454/1965 442 400 auto. The 78 Bu parted out 1/15. 68 Velle parting as of 3/15
Chevelle Tech > General Tech Area > Performance      Current Topic: Engine Weights SBC-vs-BBC-vs-BBC
Human Verification
