Homemade anti-theft devices - Chevelle Tech
Auto Insurance
1999 -- Tech Files - reference area
1000's of previous topics
Old Dec 3rd, 99, 8:38 PM
davewright99 davewright99 is offline
Default
I was kicking around the idea of including a hidden Battery switch (such as for marine use) as a kind of anti-theft device for my '70 Chevelle. A hidden run of wire to a switch in the trunk would be idea for some security, but the long run would probably present some serious current delivery problems would they not? Has anyone heard of any "home-made" type of anti-theft devices that work pretty well? Thanks
Dave
Quick reply to this message
Old Dec 4th, 99, 2:57 AM
jmw jmw is offline
Default
I have heard of a hood locking kit from Year One that allows you to lock your hood down from the interior. This sounds like a good investment.
If your switch is for the main feed to the starter, yes, if you do not get bigger conductor wire, you risk overheating the cable and degrading the insulation from the inside out. Also note that people who have put the battery in the trunk usually relocate the solenoid back there also to avoid having a constantly energized cable running the length of the car. In your case you'd have two.
I am also going to add a hidden switch in the console. I have the wiring diagram, just haven't looked it over for the best place(s) to do the interlock.
jmw
Old Dec 4th, 99, 5:56 AM
chev-hell chev-hell is offline
John
Default
try hooking up a push-button on/off switch,(locate it on the passenger side so it's not noticable)to a relay that blows the horn as soon as the coil has power, that way if the guy is smart enough to look for a kill under the dash he won't find it, and if he attempts to even turn the power on, everyone around will know. and you won't have to splice in under the driver side where most alarms do and theives know to look for.
members.aol.com/jnkb2cool/chevelle9.jpg members.aol.com/jnkb2cool/350.jpg
John Krenn
1970 malibu SS look-a-like well kinda
307/200-4r (soon to be 355 or 383)
Ft.Worth, Tx
Old Dec 4th, 99, 6:52 AM
Dean Dean is offline
Default
Hey that's a good idea chev-hell,
Make it look like it might be the "hidden switch" that is disabeling the car from starting and he will be sure to try it.
Take it one step farther and use a relay with an extra set of "normally open" contacts and wire them up to a holding circuit so that the relay keeps itself inergized and the horn won't stop.
Dean Call
Team Gold member #3
A.C.E.S. # 00235
N.C.O.A. # 4350
M.A.C.C. # 001
macc.chevelles.net
Old Dec 4th, 99, 7:36 AM
KeeBird KeeBird is offline
Default
That is really funny you guys! (Because I know it would work!) If this is going to be used in public places you might want to limit the time that the horn will sound. I don't know about other parts of the country, but here is Los Angeles if your alarm or horn sounds for 10 or 20 minutes it can be towed away by the city as a nuisance!
Kee
  #6
Old Dec 4th, 99, 8:29 AM
Fred Ont canada Fred Ont canada is offline
Default
How about a solenoid connected to the trigger on a 45 pointed at the drivers seat.That way you would know who it was.Just don't forget to disconnect it...FRED
  #7
Old Dec 4th, 99, 8:34 AM
Default
Hey Chev-hell; thanks for the idea! That's a good one! Would you also be able to add an "under the dash" passenger side switch wired into the starter solenoid circuit?
dave
  #8
Old Dec 4th, 99, 9:11 AM
Coppertop Coppertop is offline
Gold Member
Joe
Default
Well, this is more fun than anti-theft, but you never know...
I was toying with the idea of some how running circuitry to the driver's side door handle on my '70 so when someone touches it the radio would light up and start playing Little Richard's "I hear you knockin' but you can't come in" --remember the Movie "Christine" written by Stephen King.
Some how use the same electronic circuitry found in those annoying "touch lamps" where you touch the base and the bulbs turn off or on. Then have a remote control that turns off this "feature" when I go to grab the door handle.
The actual music would come from a hidden module.
Cool, but I don't have that much free time.
Joe
  #9
Old Dec 4th, 99, 10:29 AM
68Malibu Blown 406 68Malibu Blown 406 is offline
Default
I like to use a toggle switch, which gnds the negative side of the coil. this way, the car cranks but will not start. This is great for hei or points or?
  #10
Old Dec 4th, 99, 10:46 AM
John
Default
oh oh i forgot have yall seen those "clubs" that Shock you if you touch em?? i love coming up with thing to do with 12volts in a car , when it comes to 12volts im a genius
John Krenn
Ft.Worth, Tx
  #11
Old Dec 5th, 99, 1:36 AM
Pat Kelley Pat Kelley is offline
Default
Here's an idea I was kicking around.
It uses a button, camouflaged in the cig lighter, and a potential relay (the contacts can be closed with a momentary switch and will stay closed until power through the load contacts is interupted). This is wired so you push the button while turning on the key, once the key is on you can release the button. Power is now supplied to the ignition. Turn off the key, the contacts open, and the car won't start until you push the button and turn the key on again.
Not really great protection but most theives will be looking for something more complicated.
Pat Kelley
66 El Camino, daily driver
67 El Camino, STRIP/street
[This message has been edited by Pat Kelley (edited 12-05-99).]
  #12
Old Dec 5th, 99, 4:12 AM
Bob B. Bob B. is offline
Default
My car is an automatic so I put in a switch to break the current from the neutral safety switch,this also works if you have an electric fuel pump
  #13
Old Dec 5th, 99, 7:39 AM
Default
Coppertop I think it should play the Cops theam - "Bad boys"
LOUD
Dean Call
Team Gold member #3
A.C.E.S. # 00235
N.C.O.A. # 4350
M.A.C.C. # 001
macc.chevelles.net
  #14
Old Dec 5th, 99, 9:20 AM
catman catman is offline
Send a message via ICQ to catman
Default
now this is a good post ,,,, I have a switch hidden under dash that cuts the power to the fuel pump <if you have mehanical pump just use a duel tank switch/valve> these days you never know what can happen , just look at stolen Chevelle section ! Do eveything you can think of to keep your baby safe from thiefs , disableing fuel system may be the best because a thief isnt going to have time to dianose problem when they are sitting in a intersection with a dead motor I have enen thought of moving switch down closer to gas pedal so it can be fliped with a foot in case of car jacking <I live in a not so nice area :-( > I do like the .45 under dash idea , too bad its illegal, I think cleaning up the mess afterwards would be worth it
John
Catapiller Mechanic
Salinas,Ca
70SS 454 Clone {in construction}
  #15
Old Dec 5th, 99, 10:16 AM
DJRisberg DJRisberg is offline
Default
A large to very large dog. Train him/her to stay off the car ofcourse, and then put him/her on a 3 ft cable, that has a ring on one end that has another cable ~ 40 feet, that goes around your car (on ground) and hooks together in a continuous loop. This allows Fido free run all the way around the car, so he can turn any would-be thief to FUBAR...
Good audible alarm too...In '88, mine saved my '69 'Meano from a 3AM joy-ride by a recent parole-ee...Well, that and open headers and no knowledge on the part of the thief of an M-22 shift pattern...dumbass kept putting it into 4th and killin' the motor. This gal (yep) actually had the gaul to ask me for a ride after I confronted her w/ a pistol...She got one by the local County Deputy.
Oh yeah, I stopped leavin' my keys in the car after that...Guess I should have put this tidbit in the "dumb things you want to admit to post"
68 El Camino...Slow, Much Work Required
98 Z28...Fast, No Work Required
Goodfellow AFB, San Angelo, TX -- Where? That's what I said..
Chevelle Tech > Team Chevelle > Archives > 1999 --      Current Topic: Homemade anti-theft devices
Location
*REQUIRED*
Insurance
First Name
Human Verification
You may not post new threads
You may not post replies
